Page 3 of 4 1 2 3 4
Re: Change in direction w/ carburetor [Re: fast68plymouth] #2611696
01/24/19 05:40 PM
01/24/19 05:40 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Originally Posted By fast68plymouth
The throttle plate itself looks to have blind screws.
Throttle plate? Screws? On the left?
It looks more like a main body sitting on a table to me.
Nice table cloth!
Yeah, ain't nuthin' but a bare body shown for the BLP.
Re: Change in direction w/ carburetor [Re: justinp61] #2611703
01/24/19 05:47 PM
01/24/19 05:47 PM
BradH Offline OP
BradH  Offline OP
Originally Posted By justinp61
My carb started as a Bigs 950HP...
Funny thing... what Bigs calls a "950" uses the 1.40" venturi main body that QFT/Proform call an "850".
The QFT/Proform "950" has a 1.45" venturi, along w/ stepped downleg boosters, rather than non-stepped downlegs their "850" uses.
shruggy
Re: Change in direction w/ carburetor [Re: BradH] #2611711
01/24/19 05:57 PM
01/24/19 05:57 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
It seems the number is marketing hoo-ha?
Hijack: Would you happen to know of any reason I can't put Proform or QFT metering blocks on my old "1000" (?) Race Demon? The way the bowl sort of wraps around the stock metering blocks makes me question it some. I'd like to get a better tune happening on it as soon as I get some more test time with the QFT Brawler 950.
Rich H.
Esse Quam Videri
Re: Change in direction w/ carburetor [Re: fast68plymouth] #2611747
01/24/19 07:28 PM
01/24/19 07:28 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Haha! I looked at it at least twice too!
Re: Change in direction w/ carburetor [Re: BradH] #2611751
01/24/19 07:33 PM
01/24/19 07:33 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
If I had to guess the right one flows better. I know nothing about it (obviously) so I have to go with my eye which sees invisible throttle plates! haha
Re: Change in direction w/ carburetor [Re: BradH] #2611829
01/24/19 10:34 PM
01/24/19 10:34 PM
N.W. Indiana
DblOJoe Offline
DblOJoe  Offline
N.W. Indiana
I'm just gonna say now my bet is the 1.425" v is gonna perform at the track.
Re: Change in direction w/ carburetor [Re: BradH] #2611988
01/25/19 12:06 PM
01/25/19 12:06 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Originally Posted By BradH
Originally Posted By ccdave
Those are all very nice however you may want to try a BLP main body from Dominic at Thumper carbs. You won't be disappointed. The BLP is the ultimate 4150 main body.
I've asked for before & after test data on like-for-like venturi size & booster config comparing the BLP BX4 main body against the "traditional" HP-type 4150 main body, but have yet to see any.
I've seen the claims by the carb builders using that style of main body. It's pretty simple IMO: if they ET & MPH better than properly-tuned carbs of the same config that use HP-style main bodies, that would tell me there's something to the design.
Do they look cool? Yep.
Do they look like they "should" be an improvement vs the older style designs? Yep
Have I seen anything "real world" to justify making the switch? Still waiting...
Looks like you have already made a MASSAVE investment in cast 4150 carbs and parts. At this point why wait for someone to post results on the capabilities of a BLP main body when you can simply buy one and try it out???
Re: Change in direction w/ carburetor [Re: DblOJoe] #2611996
01/25/19 12:23 PM
01/25/19 12:23 PM
BradH Offline OP
BradH  Offline OP
The ol' Gold Claw has worked well, once the original (horrible) BG tune was corrected. But I've seen it give up 10 HP and comparable torque to Dwayne's old-school CFS-modified Holley 850 annular. I'm hoping that somewhere in this pile of shiny sh!t there's another carb that will do better, which is why the GC is still the baseline.
Re: Change in direction w/ carburetor [Re: ccdave] #2611999
01/25/19 12:26 PM
01/25/19 12:26 PM
BradH Offline OP
BradH  Offline OP
It would be nice if someone else had spent the $$$ already for the parts & tuning time, instead of leaving me to do it only to find out that looks ain't everything! laugh2
Re: Change in direction w/ carburetor [Re: BradH] #2612010
01/25/19 12:41 PM
01/25/19 12:41 PM
N.W. Indiana
DblOJoe Offline
DblOJoe  Offline
N.W. Indiana
I had a old 850 annular that drove great around the pits and I thought ran pretty good on the track. Put a small 950hp on it and went a tenth quicker. Mostly due to shift recovery.
Both were out of the box though so I'm kinda interested in your results.
Re: Change in direction w/ carburetor [Re: BradH] #2612012
01/25/19 12:50 PM
01/25/19 12:50 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
What kind of $$$ are we talking for one of those BLP bodies?
Re: Change in direction w/ carburetor [Re: fast68plymouth] #2612024
01/25/19 01:13 PM
01/25/19 01:13 PM
BradH Offline OP
BradH  Offline OP
Bare uncoated BX4 body $208 (no boosters)
Coated version for $226
+ cost of boosters... maybe $40 for banjos & $50 for billet inserts
+ cost of installation (requires some special adapter that the standard booster installation tool doesn't come with, IIRC)
I dunno... maybe $350+ ?
Re: Change in direction w/ carburetor [Re: BradH] #2612095
01/25/19 03:18 PM
01/25/19 03:18 PM
So. Burlington, Vt.
So. Burlington, Vt.
Okay....... so not crazy money.
Re: Change in direction w/ carburetor [Re: BradH] #2612106
01/25/19 03:50 PM
01/25/19 03:50 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
So is the Challenger running again?
69 GTX 68 Road Runner
Re: Change in direction w/ carburetor [Re: JERICOGTX] #2612220
01/25/19 07:26 PM
01/25/19 07:26 PM
BradH Offline OP
BradH  Offline OP
Still wrench ...
Re: Change in direction w/ carburetor [Re: fast68plymouth] #2612222
01/25/19 07:28 PM
01/25/19 07:28 PM
BradH Offline OP
BradH  Offline OP
No, but not a priority, either. I have other things to spend the $ on at this time.
Re: Change in direction w/ carburetor [Re: BradH] #2612312
01/25/19 10:42 PM
01/25/19 10:42 PM
So. Burlington, Vt.
So. Burlington, Vt.
I wasn’t suggesting you buy one....... I was really just curious about the cost.
Re: Change in direction w/ carburetor [Re: BradH] #2612872
01/27/19 02:07 AM
01/27/19 02:07 AM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Just buy a BLP main body and get er done!! Sell one of those dinosaur carbs on Craigslist to recoop your $$$$. This will end the debate and you finally be able to sleep. I really like mine!!!!!!!!
Re: Change in direction w/ carburetor [Re: fast68plymouth] #2613010
01/27/19 12:42 PM
01/27/19 12:42 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
$256 uncoated with boosters, air bleeds and squirters.
https://blp.com/cart/index.php?main_page=product_info&cPath=65_397&products_id=1601
The BLP BX4 and Bigs HP bodies.
Re: Change in direction w/ carburetor [Re: BradH] #2613013
01/27/19 12:53 PM
01/27/19 12:53 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
If someone is considering the BLP BX4 main body be aware that Holley air bleeds won't work in them unless they are turned down. I made a fixture to use in my lathe out of a piece of 3/4" aluminum round stock.
When I bought my body there was nothing in the description about the difference in the bleeds. When I received mine I was somewhat pi$$ed that my bleeds wouldn't work. The guys BLP stepped up and sent me what I needed and now there is a note at the bottom of the web page noting that BLP bleeds are needed.
Page 3 of 4 1 2 3 4
