Re: Change in direction w/ carburetor
[Re: fast68plymouth]
#2611696
01/24/19 05:40 PM
01/24/19 05:40 PM
BradH
The throttle plate itself looks to have blind screws. Throttle plate? Screws? On the left? It looks more like a main body sitting on a table to me. Nice table cloth! Yeah, ain't nuthin' but a bare body shown for the BLP.
[Re: justinp61]
#2611703
01/24/19 05:47 PM
01/24/19 05:47 PM
BradH
My carb started as a Bigs 950HP...
Funny thing... what Bigs calls a "950" uses the 1.40" venturi main body that QFT/Proform call an "850". The QFT/Proform "950" has a 1.45" venturi, along w/ stepped downleg boosters, rather than non-stepped downlegs their "850" uses.
[Re: BradH]
#2611711
01/24/19 05:57 PM
01/24/19 05:57 PM
Posts: 17,864 S.E. Michigan
ZIPPY
S.E. Michigan
It seems the number is marketing hoo-ha?
Hijack: Would you happen to know of any reason I can't put Proform or QFT metering blocks on my old "1000" (?) Race Demon? The way the bowl sort of wraps around the stock metering blocks makes me question it some. I'd like to get a better tune happening on it as soon as I get some more test time with the QFT Brawler 950.
Rich H.
Esse Quam Videri
#2611747
01/24/19 07:28 PM
01/24/19 07:28 PM
Posts: 2,363 Cotati, CA
Dave Hall
Cotati, CA
The throttle plate itself looks to have blind screws. Throttle plate? Screws? On the left? It looks more like a main body sitting on a table to me. Haha! I looked at it at least twice too!
[Re: BradH]
#2611988
01/25/19 12:06 PM
01/25/19 12:06 PM
Posts: 1,807 Mopar Country, Mi
ccdave
The Ultimate
The Ultimate
Mopar Country, Mi
Those are all very nice however you may want to try a BLP main body from Dominic at Thumper carbs. You won't be disappointed. The BLP is the ultimate 4150 main body. I've asked for before & after test data on like-for-like venturi size & booster config comparing the BLP BX4 main body against the "traditional" HP-type 4150 main body, but have yet to see any. I've seen the claims by the carb builders using that style of main body. It's pretty simple IMO: if they ET & MPH better than properly-tuned carbs of the same config that use HP-style main bodies, that would tell me there's something to the design. Do they look cool? Yep. Do they look like they "should" be an improvement vs the older style designs? Yep Have I seen anything "real world" to justify making the switch? Still waiting... Looks like you have already made a MASSAVE investment in cast 4150 carbs and parts. At this point why wait for someone to post results on the capabilities of a BLP main body when you can simply buy one and try it out???
[Re: BradH]
#2612012
01/25/19 12:50 PM
01/25/19 12:50 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
What kind of $$$ are we talking for one of those BLP bodies?
#2612024
01/25/19 01:13 PM
01/25/19 01:13 PM
BradH
What kind of $$$ are we talking for one of those BLP bodies? Bare uncoated BX4 body $208 (no boosters) Coated version for $226 + cost of boosters... maybe $40 for banjos & $50 for billet inserts + cost of installation (requires some special adapter that the standard booster installation tool doesn't come with, IIRC) I dunno... maybe $350+ ?
[Re: BradH]
#2612095
01/25/19 03:18 PM
01/25/19 03:18 PM
fast68plymouth
So. Burlington, Vt.
Okay....... so not crazy money.
[Re: BradH]
#2612106
01/25/19 03:50 PM
01/25/19 03:50 PM
Posts: 10,032 MN
JERICOGTX
MN
So is the Challenger running again?
69 GTX
68 Road Runner
[Re: BradH]
#2612312
01/25/19 10:42 PM
01/25/19 10:42 PM
fast68plymouth
So. Burlington, Vt.
I wasn’t suggesting you buy one....... I was really just curious about the cost.
