Page 1 of 3 1 2 3
Can you make a Dominator carb streetable? #2610168
01/21/19 11:40 PM
01/21/19 11:40 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
shruggy
'63 Dodge 330
11.19 @ 121 mph
Re: Can you make a Dominator carb streetable? [Re: GY3] #2610175
01/21/19 11:50 PM
01/21/19 11:50 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Yes up
Re: Can you make a Dominator carb streetable? [Re: GY3] #2610187
01/22/19 12:07 AM
01/22/19 12:07 AM
AndyF Offline
AndyF  Offline
Having a big engine helps but you're opening up a lot of throttle area so low speed response is always going to be a bit iffy. A lightweight car with stiff gears will help of course. A big cam is going to make the low speed throttle response even worse and of course, most people who put a Dominator on a street car also use a big cam.
Re: Can you make a Dominator carb streetable? [Re: AndyF] #2610189
01/22/19 12:11 AM
01/22/19 12:11 AM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
How streetable you need it?
Here is my Street car with a 1250 on it.....Can't drive it in the winter though...
https://www.youtube.com/watch?v=WYw6RA-k5Bk&t=18s
Re: Can you make a Dominator carb streetable? [Re: GY3] #2610192
01/22/19 12:14 AM
01/22/19 12:14 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I actually feel that they’re easier to dial in for street duty when the cam is on the big side(lower engine vacuum), since that’s what the low speed circuits are designed to be used with.
Re: Can you make a Dominator carb streetable? [Re: fast68plymouth] #2610200
01/22/19 12:29 AM
01/22/19 12:29 AM
iagree up
I like to use one of the original non HP list # 9375 for a single plane intake on the street and at the track up scope
I due lean down the transition circuit to keep the motor happy(spark plugs clean) and not real fat at part throttle cruise up scope
Re: Can you make a Dominator carb streetable? [Re: GY3] #2610204
01/22/19 12:33 AM
01/22/19 12:33 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
You need to get thumped! wave
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Can you make a Dominator carb streetable? [Re: GY3] #2610366
01/22/19 12:31 PM
01/22/19 12:31 PM
an8sec70cuda Offline
Yes. Pro Systems did a great job w/ mine.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Can you make a Dominator carb streetable? [Re: GY3] #2610368
01/22/19 12:46 PM
01/22/19 12:46 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I have ran Dominators on my mostly street cars for over 15 years. No difference in driving quality vs a 4150 when set up right. And Thumper is the man to do that.
If your combo needs/wants that much carb, there is no reason not to.
drive
Master, again and still
Re: Can you make a Dominator carb streetable? [Re: GY3] #2610406
01/22/19 02:04 PM
01/22/19 02:04 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
If you can find one reasonable, the original nascar dominators had a choke. Many years ago I ran one of them on the street and it worked as good as any carb. Never tried a newer style.
https://www.ebay.com/itm/NOS-Holley-4575...B-/182382372125
Re: Can you make a Dominator carb streetable? [Re: GY3] #2610415
01/22/19 02:17 PM
01/22/19 02:17 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Make sure its 3 circuit.
Re: Can you make a Dominator carb streetable? [Re: dthemi] #2610473
01/22/19 03:44 PM
01/22/19 03:44 PM
AndyF Offline
AndyF  Offline
I'd never recommend a 3 circuit for the street. You can kill an engine on a short freeway drive with a 3 circuit. Driving at part throttle with the manifold vacuum under the throttle blade sucking fuel right out of the intermediate dump tubes will wash the cylinders and stick the rings. I've seen customers over the years destroy expensive engines doing that.
Re: Can you make a Dominator carb streetable? [Re: AndyF] #2610476
01/22/19 03:49 PM
01/22/19 03:49 PM
iagree
That is why I lean down the transition and idle circuits to prevent them being way to rich at light part throttle cruise on the street scope Dominic, Thumper Dart,760-900-3895, can fix them up for anyone wanting to drive a 3 circuit on the street up
Re: Can you make a Dominator carb streetable? [Re: GY3] #2610482
01/22/19 04:00 PM
01/22/19 04:00 PM
FWIW...My Pro Systems 1200 cfm dominator is a 3 circuit carb. Granted it's obviously been modified, but the 3 circuit carbs can be made to work.
As delivered from Holley, the 3 circuit carbs are pig fat and run like crap at part throttle.
CHIP
Re: Can you make a Dominator carb streetable? [Re: GY3] #2610485
01/22/19 04:07 PM
01/22/19 04:07 PM
So. Burlington, Vt.
So. Burlington, Vt.
Frankly.......... the ootb 2 circuits aren’t much better.
For truely street friendly manners, any of them are going to need some mods.
Re: Can you make a Dominator carb streetable? [Re: GY3] #2610492
01/22/19 04:16 PM
01/22/19 04:16 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Absolutely! Call Dom at Thumpercarbs. Can find him on Facebook. He builds them weekly and is the best in the business in my opinion. I have one of his and it's the best carb I have ever owned.
Re: Can you make a Dominator carb streetable? [Re: mopar dave] #2610497
01/22/19 04:19 PM
01/22/19 04:19 PM
kansas
farmboy Offline
farmboy  Offline
kansas
Ditto
Re: Can you make a Dominator carb streetable? [Re: Cab_Burge] #2610603
01/22/19 07:14 PM
01/22/19 07:14 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I'd never recommend a 3 circuit for the street...
iagree
... Dominic, Thumper Dart,760-900-3895, can fix them up for anyone wanting to drive a 3 circuit on the street up
Yeah, but they're not 3-circuits any longer once he's gone through 'em. laugh2
Anyone have experience w/ the HP-style 8082 1050? I'd heard that's more like the old-style 9375, in that it's a 2-circuit intended for a single 4-bbl application. It's not one of the fancy "new gen" billet series, though.
Re: Can you make a Dominator carb streetable? [Re: GY3] #2610620
01/22/19 07:47 PM
01/22/19 07:47 PM
hemi-itis Offline
hemi-itis  Offline
I'D bet he would get into the 10's with a thumperized tater! up
Re: Can you make a Dominator carb streetable? [Re: hemi-itis] #2610630
01/22/19 08:17 PM
01/22/19 08:17 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Been 10's already...
'63 Dodge 330
11.19 @ 121 mph
Page 1 of 3 1 2 3
