Opinions on B&M and Hughes torque converters? #2608241
01/17/19 08:07 PM
01/17/19 08:07 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Hi all,
I've just had a new 440 built, and want to use a lower-stall torque converter than the 3,000 rpm that was in it previously. My engine is making 448 hp @ 5,000 rpm, and 507 lb ft of torque at 4,000 rpm. It's a 440-6, going into my '71 Satellite, and will be street driven 99.9% of the time. I want a stall speed of 2300-2600 rpm, and am looking at the following two converters:
B&M Holeshot 2400
Hughes Performance Street Master
Any opinions, pro or con, would be appreciated. Thanks!
Roger
Re: Opinions on B&M and Hughes torque converters? [Re: Fab64] #2608256
01/17/19 08:50 PM
01/17/19 08:50 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
I put the Street Master in my old wagon when I put the 440 in it. Worked well for me. No complaints at all.
Scott
1969 Super Bee, 383/4 speed
Re: Opinions on B&M and Hughes torque converters? [Re: Fab64] #2608260
01/17/19 09:04 PM
01/17/19 09:04 PM
Colorado front range
BcudaChris Offline
BcudaChris  Offline
Nice numbers! You want to match your stall to your power band. I'd check with Cope or another custom builder. For your purposes, a custom converter would be in the ballpark price wise with an off the shelf unit. Unless I miss my guess.
Re: Opinions on B&M and Hughes torque converters? [Re: Fab64] #2608277
01/17/19 09:31 PM
01/17/19 09:31 PM
Montreal Quebec
STROKIE Offline
STROKIE  Offline
Montreal Quebec
I use B&M Holeshot 2400 very good results on my Dodge Charger...
https://youtu.be/tt-x-_3jjmE
Re: Opinions on B&M and Hughes torque converters? [Re: STROKIE] #2608287
01/17/19 09:46 PM
01/17/19 09:46 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Thanks for the input, guys. I'm using a cam from Bob Karakashian (Mr Six Pack), and 2300-2600 was the stall range he recommended. I want it to drive more like a stock '70-71 car, and be more streetable. I really didn't like the 3.000 rpm stall that the prior owner had in the car when I bought it.
Btw, nice Charger, Strokie!
Re: Opinions on B&M and Hughes torque converters? [Re: Fab64] #2608320
01/17/19 11:28 PM
01/17/19 11:28 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
a stock converter will flash at 2300rpm with that engine. I wouldn't use anything much looser than stock.
Re: Opinions on B&M and Hughes torque converters? [Re: Fab64] #2608492
01/18/19 10:48 AM
01/18/19 10:48 AM
Montreal Quebec
STROKIE Offline
STROKIE  Offline
Montreal Quebec
Thanks, I also use a cam from Bob Karakashian (Mr Six Pack). up
Re: Opinions on B&M and Hughes torque converters? [Re: Fab64] #2609812
01/21/19 12:19 PM
01/21/19 12:19 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
I used the holeshot 2400 in my bb dart when I first put it together. Seemed to work fine.
Re: Opinions on B&M and Hughes torque converters? [Re: Fab64] #2610029
01/21/19 07:53 PM
01/21/19 07:53 PM
CA
crackedback Online content
crackedback  Online Content
CA
Neither...
People spend thousands of dollars on an engine combo. When it comes time to buy the MOST important piece of the puzzle in an auto trans car, they look for the cheapest way out on a converter.
Spend the money on a good converter that flashes hard and is still tight on cruise. A good converter shop can build one and will run from 500-850.
I know plenty of people that put one of the shelf units in a car. They replaced it with a custom ones, with a higher flash, and it ran LOWER rpm at highway speeds. Go figure. It's done all the time now. GOOD Higher stall stuff runs without the 70's stepping on a marshmellow sloppy feel.
