Re: Headers for my 499" B1MC headed Bonneville bullet
[Re: mopar dave]
#2608943
01/19/19 12:44 PM
01/19/19 12:44 PM
Posts: 248 near St Petersburg, FL
Lifsgrt
Hey Dave, does the program show the same numbers if you change the rpm to 8000 or 8500? Might need to turn the pump faster to make hp. Thanks
B3 1969 Charger R/T SE, 440/727 with 3:91s running 11.07@120
[Re: Lifsgrt]
#2609232
01/20/19 05:28 AM
01/20/19 05:28 AM
Lifsgrt
Hey guys,thanks for all the feedback, I really appreciate it. I've decided to go with a two-step 2 1/4" to 2 3/8" with a 4" collector. The AlterKtion (to get rid of torsion bars and free space for the dry sump pump) should arrive next week, so I can get going on the headers. I hope to get the headers and dry sump together and stop by Best Machine on the way home to hear this beast sing! Then we'll know what it makes! Today is day 17 of the build, I've replaced inner and outer rockers, trans crossmember, and all four frame rails so far. Floor is obviously still out, and I got one wheelhouse out today with fresh one mocked in place. Finally getting something done on it! Thanks again!
[Re: Lifsgrt]
#2609233
01/20/19 05:31 AM
01/20/19 05:31 AM
Posts: 43,272 Bend,OR USA
Cab_Burge
What car year and body style are you going to run on the salt flats?
[Re: Lifsgrt]
#2609464
01/20/19 07:11 PM
01/20/19 07:11 PM
Posts: 8,043 Mt Morris Michigan
mopar dave
Mt Morris Michigan
OK, using 8500rpm target with same 111.24 VE/394 flow gets you 2.236-2.361 tube size 25.2-28.2 length. Collector length 13.8 or 6.9. Collector Dia 4.204-4.704 AVG HP 1156/769 TQ, HP/CI 2.321
[Re: Cab_Burge]
#2609748
01/21/19 04:55 AM
01/21/19 04:55 AM
Lifsgrt
Hey Cab, I'm planning to make Speed Week in August, touch base with me before to confirm. Definitely something a car guy should do before he pops the 'chute!
[Re: mopar dave]
#2609750
01/21/19 04:59 AM
01/21/19 04:59 AM
Lifsgrt
Hey Dave, can you hang that 8500rpm data or send it to me? I would like to se ethe rest of the numbers. It looked like you were describing a two step header, thanks.
[Re: 440GTX]
#2609751
01/21/19 05:00 AM
01/21/19 05:00 AM
Lifsgrt
440GTX, what power and torque is that monster making?
[Re: Lifsgrt]
#2609868
01/21/19 02:15 PM
01/21/19 02:15 PM
Posts: 213 poughquag, NY
440GTX
poughquag, NY
440GTX, what power and torque is that monster making? 1240 hp and 920 ft pounds of torque
[Re: 440GTX]
#2609935
01/21/19 04:20 PM
01/21/19 04:20 PM
Posts: 4,691 On the parachute mount
n20mstr
440GTX, what power and torque is that monster making? 1240 hp and 920 ft pounds of torque SHOW OFF!! I was going to respond to this, but im not LOL
....BAD A$$ STREET CAR.....
[Re: Cab_Burge]
#2610177
01/21/19 11:55 PM
01/21/19 11:55 PM
Lifsgrt
Hey Cab, building a 1969 Daytona clone for the task. I'm in Buckley, WA, come on up and have a look!
[Re: 440GTX]
#2610180
01/21/19 11:57 PM
01/21/19 11:57 PM
Lifsgrt
That's certainly stout 440GTX, thanks. How did you determine what type merge collector to go with, or did you just pick what you wanted? Do you have comparison with non-merge collectors by chance?
