Stock converter 1967 426 hemi. Find it Where? #2606757
01/15/19 01:59 AM
01/15/19 01:59 AM
northwest USA
N
NANKET Offline OP
NANKET  Offline OP
N
northwest USA
Where to find a stock torque converter for a 67 street hemI? Any rebuilders have them like the #764 340 unit?
Re: Stock converter 1967 426 hemi. Find it Where? [Re: NANKET] #2606774
01/15/19 02:49 AM
01/15/19 02:49 AM
So Near, Yet So Far
topside Offline
topside  Offline
So Near, Yet So Far
Try calling Pat Blais in the Seattle area. He's on Ebay as tflite_patty or something similar.
Re: Stock converter 1967 426 hemi. Find it Where? [Re: NANKET] #2606775
01/15/19 02:52 AM
01/15/19 02:52 AM
northwest USA
N
NANKET Offline OP
NANKET  Offline OP
N
northwest USA
Do they come up on eBay or any classifieds?
I Recinded status as a blazing customer years ago.
Re: Stock converter 1967 426 hemi. Find it Where? [Re: NANKET] #2606923
01/15/19 02:09 PM
01/15/19 02:09 PM
Iowa
ratroaster Offline
ratroaster  Offline
Iowa
I seen this the other day. Pricing not shown. You would have to call. I do know they are a good reputable company. Precision torque
Re: Stock converter 1967 426 hemi. Find it Where? [Re: NANKET] #2606976
01/15/19 03:43 PM
01/15/19 03:43 PM
New Jersey
69Chrgr Offline
69Chrgr  Offline
New Jersey
Call Frank Lupo @ Dynamic Converters in Newark Delaware, he may have an original core or point you in the right direction.
Re: Stock converter 1967 426 hemi. Find it Where? [Re: NANKET] #2607059
01/15/19 06:14 PM
01/15/19 06:14 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The Hemi converter is just a 764 with larger threads in the drive lugs. Some claim to have tapped the lugs oversize in situ.
Re: Stock converter 1967 426 hemi. Find it Where? [Re: NANKET] #2607071
01/15/19 06:35 PM
01/15/19 06:35 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the lugs are different for a 7/16" bolt street hemi converter than a 5/16" bolt 383 converter. pretty sure a 383 4bbl converter, other than lugs, is the same as a street hemi. the street hemi 7/16" lug is fatter were the threaded bolt hole is vs the 5/16".
Re: Stock converter 1967 426 hemi. Find it Where? [Re: NANKET] #2607120
01/15/19 07:50 PM
01/15/19 07:50 PM
northwest USA
N
NANKET Offline OP
NANKET  Offline OP
N
northwest USA
The hemi converter has a bump in the case just outside of the snout, the front pump needs to be clearanced so the converter doesn't rub the pump body.
Re: Stock converter 1967 426 hemi. Find it Where? [Re: NANKET] #2607122
01/15/19 07:52 PM
01/15/19 07:52 PM
northwest USA
N
NANKET Offline OP
NANKET  Offline OP
N
northwest USA
Yes the 7/16 lugs are much larger than the 340 converter.
Re: Stock converter 1967 426 hemi. Find it Where? [Re: NANKET] #2607148
01/15/19 08:46 PM
01/15/19 08:46 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The machining you show isn't for a factory Hemi converter which has the same bowl as any other 10 3/4" converter. Only for the 10" and smaller require pump cover machining.
Re: Stock converter 1967 426 hemi. Find it Where? [Re: lewtot184] #2607151
01/15/19 08:50 PM
01/15/19 08:50 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yeah, that's the 764 I mentioned....also used on the /6, 318 and 340.
Re: Stock converter 1967 426 hemi. Find it Where? [Re: NANKET] #2607193
01/15/19 09:46 PM
01/15/19 09:46 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i'm using a '66 street hemi converter with my '65 cable trans. didn't do any pump work. just stuck it in and motored on.
Re: Stock converter 1967 426 hemi. Find it Where? [Re: NANKET] #2607218
01/15/19 10:14 PM
01/15/19 10:14 PM
northwest USA
N
NANKET Offline OP
NANKET  Offline OP
N
northwest USA
Well OK that's why I asked. Don't know these details.
Re: Stock converter 1967 426 hemi. Find it Where? [Re: NANKET] #2607237
01/15/19 11:07 PM
01/15/19 11:07 PM
Iowa
ratroaster Offline
ratroaster  Offline
Iowa
I know some have said the clearance issue is on the opposite side of the converter. I have heard the crank side of the converter is clearanced more for the 8 bolt crankshaft mounting. You can do it but need to use thin headed bolts or there is interferance. No experience here, just what I read on here.
Re: Stock converter 1967 426 hemi. Find it Where? [Re: NANKET] #2607248
01/15/19 11:33 PM
01/15/19 11:33 PM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
I had one in my 68 rr, 383, no modifications to run it.
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: Stock converter 1967 426 hemi. Find it Where? [Re: NANKET] #2607253
01/15/19 11:44 PM
01/15/19 11:44 PM
northwest USA
N
NANKET Offline OP
NANKET  Offline OP
N
northwest USA
Did it work any different than the stock converter in the 68 RR?
Re: Stock converter 1967 426 hemi. Find it Where? [Re: Prodart440] #2607266
01/15/19 11:57 PM
01/15/19 11:57 PM
Iowa
ratroaster Offline
ratroaster  Offline
Iowa
Not what I'm saying. You could run a hemi converter on a 383 crank but not vise-versa without the thin bolt heads......
Re: Stock converter 1967 426 hemi. Find it Where? [Re: ratroaster] #2607578
01/16/19 04:11 PM
01/16/19 04:11 PM
moparx Offline
moparx  Offline
how thin are the heads ? would grade 8 bolts be ok to machine down the heads ? if so, a thickness dimension would be great to have ! got tons of regular grade 8 bolts in stock.
TIA bow
Re: Stock converter 1967 426 hemi. Find it Where? [Re: moparx] #2607587
01/16/19 04:20 PM
01/16/19 04:20 PM
Iowa
ratroaster Offline
ratroaster  Offline
Iowa
Not sure I have not done it. Just what I read on here. Read this old thread I found. Hemi converter thread
Re: Stock converter 1967 426 hemi. Find it Where? [Re: ratroaster] #2607607
01/16/19 04:46 PM
01/16/19 04:46 PM
moparx Offline
moparx  Offline
thanks for the link, but the last part contained a follow up link to a pic [i think that would show the bolt head thickness] that was not available due to the "file being empty".
most likely because the post was from 2010.
beer
