Wire Harness Clips ? Firewall and Brake warning. #2605633
01/12/19 11:14 PM
01/12/19 11:14 PM
Phila. Pa.
Mattax Offline OP
Mattax  Offline OP
Phila. Pa.
Looking for information on the wire loom support that clipped to the pinch weld 1967-8 A-bodies.
Did all A-bodies get one?
Are these the same as used on the '66 and earlier cars?
Also was a clip to hold the wire for the brake warning switch?
Attached is a closeup of the clip on a '67, as well as a photo of '68 GTS unrestored with arrows showing the locations I'm asking about.
Mitch's68GTS383-engine-006m.jpg002-wind-1967-plymouth-barracuda-closeup-firewall-clip.jpg
Re: Wire Harness Clips ? Firewall and Brake warning. [Re: Mattax] #2613014
01/27/19 12:54 PM
01/27/19 12:54 PM
Phila. Pa.
Mattax Offline OP
Mattax  Offline OP
Phila. Pa.
No part number yet, but some confirmation its probably the same as used on early A bodies.
Probably looks like this.
