A/C condenser: new or old? #2605350
01/12/19 12:57 PM
01/12/19 12:57 PM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
When adding A/C to your car would you rather get a new condenser (aluminum most likely) or use a nice original condenser (brass?)?
It seems the old ones are of a better quality?
Re: A/C condenser: new or old? [Re: DGS] #2605358
01/12/19 01:13 PM
01/12/19 01:13 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
Original always fits the best and most likely made better.
Re: A/C condenser: new or old? [Re: DGS] #2605368
01/12/19 01:52 PM
01/12/19 01:52 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
The new one that is made to use r134a, NOT R12 like the original one is.
Re: A/C condenser: new or old? [Re: DGS] #2605375
01/12/19 01:57 PM
01/12/19 01:57 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I have my original but will install a new aluminium replacement, but direct stock replacement, exactly same piece than original
this is for 73/74 Charger
https://www.ebay.com/itm/73-74-Dodge-Ply...aeVlC:rk:1:pf:0
Aluminium disipates better the heat so should be better to get more cold into the cab, I guess. I hope my car will be working this year to check it.
Re: A/C condenser: new or old? [Re: DGS] #2605383
01/12/19 02:10 PM
01/12/19 02:10 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
I got an NOS unit for my car when I did it . . . . although the original in the car still looked good, I did not want to take a chance . . . pretty sure the OE and NOS unit were Aluminum . . .
Re: A/C condenser: new or old? [Re: a12rag] #2605393
01/12/19 02:32 PM
01/12/19 02:32 PM
moparx Offline
moparx  Offline
i was going to say the same thing. back in my junkyard ownership days, [1972-1984] we sold radiators [brass/copper] and condensers [aluminum] separately for scrap.
i can't remember ever seeing a copper/brass condenser from any american manufacturer.
beer
Re: A/C condenser: new or old? [Re: moparx] #2605452
01/12/19 03:58 PM
01/12/19 03:58 PM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
beer
Good to know! I thought they were brass like the radiators are.
Re: A/C condenser: new or old? [Re: DGS] #2605457
01/12/19 04:11 PM
01/12/19 04:11 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
my original ( Charger 74 ) IS NOT aluminium... is iron
Re: A/C condenser: new or old? [Re: DGS] #2605520
01/12/19 06:28 PM
01/12/19 06:28 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I would use a new one unless you are charging the system with R12. R12 is a better refrigerant that R134A, so in order to dump the same amount of heat, R134A requires a more efficient condenser. Modern universal, retrofit and reproduction condensers are made for R134A so your vintage R12 condenser may not cool well especially at low speeds.
Re: A/C condenser: new or old? [Re: DGS] #2605530
01/12/19 06:53 PM
01/12/19 06:53 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Now sure how a more efficient condenser would cool worse with R12 than R134.
Don't be the exception.
Re: A/C condenser: new or old? [Re: DGS] #2605683
01/13/19 12:34 AM
01/13/19 12:34 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
The increased surface area accompanied with a stacked plate [modern] style condenser is a more efficient design than a tube and fun [old].
Unless OEM-like aesthetics take priority, I don't see why you would run a tube and fin. Aside from potentially being cheaper.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: A/C condenser: new or old? [Re: DGS] #2605791
01/13/19 11:24 AM
01/13/19 11:24 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
I converted my old pickup from r12 to r134 a long time ago. I also changed to a rotary compressor at that time. The AC worked OK but not as good as before. An AC expert friend of mine convinced me to change to a condenser designed for r134. I changed the condenser to one specifically intended for r134. The difference was remarkable. My pickup cools much better now.
Re: A/C condenser: new or old? [Re: NachoRT74] #2605792
01/13/19 11:26 AM
01/13/19 11:26 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
I think that would be the compressor?
Re: A/C condenser: new or old? [Re: TooMany62s] #2605810
01/13/19 12:12 PM
01/13/19 12:12 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
no, I'm talking about the condenser. It got a crack once and was fixed at the Y on top passenger side. Is the same iron tube as far I could tell used on gas and tranny oil colling lines.
But definitelly is not aluminium
Re: A/C condenser: new or old? [Re: GoodysGotaCuda] #2605812
01/13/19 12:15 PM
01/13/19 12:15 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
there are two kinds of these... serpent tube which is the original kind and parallel tubes which has being told is more efficient ?.
In my case I'm going original design but aluminium just right to keep same original look.
Re: A/C condenser: new or old? [Re: NachoRT74] #2605908
01/13/19 03:22 PM
01/13/19 03:22 PM
moparx Offline
moparx  Offline
i have seen fittings of a type of steel silver soldered, or brazed, onto an aluminum condenser tube. the reason being, that steel and aluminum will corrode together, making removal of the threaded fitting impossible without destroying one, or both threaded fittings. we always chopped those off with bolt cutters before tossing them in the scrap pile. maybe your condenser was like that ? an iron condenser would weigh a ton [figuratively speaking], and i would think as thin as the tube mass is, would have cracking issues from vibrations that are always present. maybe export stuff was/is different than anything i have experience with ? shruggy or possibly, your condenser was a light weight steel tube design ? occasionally, we would run across one of those, but could immediately identify it based on just how heavy it "felt", as opposed to the "normal" aluminum condensers.
beer
Re: A/C condenser: new or old? [Re: DGS] #2606219
01/13/19 11:58 PM
01/13/19 11:58 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I have had both in hands, my original and the new aluminium one I have... the original IS NOT ALUMINIUM. tsk beer
Re: A/C condenser: new or old? [Re: DGS] #2606236
01/14/19 12:37 AM
01/14/19 12:37 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
put a magnet on it
Re: A/C condenser: new or old? [Re: DGS] #2606264
01/14/19 01:26 AM
01/14/19 01:26 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
The fix/weld was made in fact with acetylene gas and copper wire! ( dunno how you call that kind of welding job ). That is not posible with aluminium.
( my car is 1k miles from home )
Re: A/C condenser: new or old? [Re: NachoRT74] #2606447
01/14/19 02:18 PM
01/14/19 02:18 PM
moparx Offline
moparx  Offline
not doubting you at all nacho. just stating my personal experience.
today, there are so many methods of joining, or repairing, unlike materials, [with, or without heat] and since i wasn't there at the time, i can only guess.
my only question is whether your original was "iron".
i'll bet our individual interpretation of material is what is causing the confusion.
"iron" to me is usually a part made of the same [type] of material an intake or exhaust manifold is made out of, or brake master cylinder, of which parts are cast.
to cast, or form, an "iron" condenser would be quite the task, plus be brittle in use as i have previously stated.
steel, on the other hand, would be easy to fab into a condenser, and be very rugged in use. i'll bet that is what you have, and i have lost that fact in translation.
sorry if i have unnecessarily ruffled your feathers ! that was not my attempt. please forgive.
beer
