Page 2 of 3 1 2 3
Re: 727 Transbrake valve body [Re: jinxy] #2603684
01/09/19 12:41 AM
01/09/19 12:41 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I have a tranzact brake in mine. Works great.
That being said I would NEVER buy one again. Good luck getting a hold of them to purchase one, let alone getting any customer service after the sale.
I've only bought a handful of parts from cope, but he ALWAYS answers the phone or calls you back.
Re: 727 Transbrake valve body [Re: jinxy] #2603710
01/09/19 01:41 AM
01/09/19 01:41 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Every time I have called Tranzact Joe has answer the phone. He must have caller ID....LOL..
Tony
70 AARCuda Vitamin C
Re: 727 Transbrake valve body [Re: jinxy] #2603818
01/09/19 11:57 AM
01/09/19 11:57 AM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
I too have no issue reaching him
eBay-cdwmotorsports
Re: 727 Transbrake valve body [Re: jinxy] #2604228
01/10/19 01:15 AM
01/10/19 01:15 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
8 30 am pst I called and Joe answered the phone this morning. Needed some help on a problem with 904...then ordered a couple parts.
Tony
Re: 727 Transbrake valve body [Re: jinxy] #2604238
01/10/19 01:33 AM
01/10/19 01:33 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Maybe he's gotten better, and good for him of he has. But I'm certainly not the only one whose had issues getting a hold of him in the past.
Again...product works great though.
Re: 727 Transbrake valve body [Re: jinxy] #2604437
01/10/19 03:12 PM
01/10/19 03:12 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
You guys might check what your caller ID looks like.
A few years ago I was trying to contact a chassis shop in Texas. They never would answer the phone. It was during the day and I was calling from work. Others would say they had zero problems talking to them.
I called one day on my cell phone and got right in myself.
Turns out when I called from work the caller ID showed the name of the bank I worked for and they would not answer it because they thought it was someone trying to sell them a credit card!
With all the spam phone calls these days many calls go unanswered based on caller ID.
Re: 727 Transbrake valve body [Re: 340Cuda] #2604466
01/10/19 03:52 PM
01/10/19 03:52 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
If they're trying to run a business they need to answer the phone or they deserve all the negative consequences for not doing so. It would be nice if the Do Not Call Registry system worked but the bad guys hamstrung it from the start with loopholes and when in charge will not enforce the weak law that does exist.
twocents
Re: 727 Transbrake valve body [Re: jinxy] #2605230
01/12/19 12:34 AM
01/12/19 12:34 AM
MI
Jeff440sc Offline
Jeff440sc  Offline
MI
Joe must have caller Id? ha ha there must be more to this. I have been trying to get a hold of Joe since last fall. I experienced a high line pressure problem with his trans brake valve body which caused the belleville spring to invert. Since he was not answering the phone when I needed help I ended up buying a new valve body from Keith Long. I had thought maybe he has health issues or other problems because he gone through some rough times in the past. I was thinking he got dementia from sanding aluminum valve bodies since he thinks he should no longer talk to me. I have known Joe for years and he always been a good guy. Joe would tell you everything he knew to help you. He would try to make things right if he made a mistake. Now this is not a good way to start a first post as a new member...I been a lurker for years but just had to chime in this time. I didn't join to talk bad about Joe. Some people said they got through on the phone, so after reading these posts I thought I would try to see if would pick up. He has no reason to avoid me far as I know. I have known Joe for over 20 years. I bought a 727 from him 20 years ago. I have been building my own stuff and have used his valve body for years without any problems. I wanted to see if Joe wanted to help me fix the high line pressure issue. So for the last 2 days I been calling but he does not pick up.
So maybe there is some truth to the caller id deal or maybe hes got dementia. Bottom line is I give up and wish him the best for what ever reason he decided to put me on the dont pick up caller id list. So now I am looking for someone who is still his friend who can still work with him with the pressure regulator spring and confirm the line pressure. I think this valve body just needs a lighter pressure regulator spring to bring down the line pressure down to 180. I think the spring he installed is 2 x what is needed. Can anyone talk to him about it or does anyone wants to buy a low band apply trans brake with a clean neutral for a 727 for 400$ - the solenoid works.
Thanks for hearing my rant
Jeff
Re: 727 Transbrake valve body [Re: jinxy] #2605236
01/12/19 12:51 AM
01/12/19 12:51 AM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
Let my dyno the valve body for ya. I can set the pressure where u want it. Test it. And send it back.
Re: 727 Transbrake valve body [Re: jinxy] #2605239
01/12/19 12:59 AM
01/12/19 12:59 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Cool stuff John!
Got my 904 stuff... thank you!
Jay
Re: 727 Transbrake valve body [Re: jinxy] #2605240
01/12/19 01:00 AM
01/12/19 01:00 AM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
Re: 727 Transbrake valve body [Re: jinxy] #2605488
01/12/19 04:53 PM
01/12/19 04:53 PM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
Cope:
Are any of your transbrake 727 valve bodies able to benused in a street/strip bracket car?
Re: 727 Transbrake valve body [Re: SILVER67] #2605496
01/12/19 05:26 PM
01/12/19 05:26 PM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
I have a trans brake in our shop truck. It has a 6.4 Hemi and a 518 transmission. all my valve bodies work on the street.
I have a trans brake in our parts delivery truck.
Re: 727 Transbrake valve body [Re: CRT] #2605498
01/12/19 05:30 PM
01/12/19 05:30 PM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
Re: 727 Transbrake valve body [Re: CRT] #2605598
01/12/19 10:08 PM
01/12/19 10:08 PM
Cab_Burge Online work
Cab_Burge  Online Work
That truck needs a dual turbo 4 cylinder Cummins in it boogie Making coal as the young guns say whistling
Re: 727 Transbrake valve body [Re: jinxy] #2605642
01/12/19 11:30 PM
01/12/19 11:30 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
I’ve never had a problem getting a hold of Joe from Tranz act my brake works great from joe
Re: 727 Transbrake valve body [Re: CRT] #2606590
01/14/19 07:58 PM
01/14/19 07:58 PM
MI
Jeff440sc Offline
Jeff440sc  Offline
MI
John,
Thank you for offering your expertise to fix the Tranzact VB.
I am willing to pay for the shipping both ways and wondering what you would accept as payment to set the pressure and be able to give it a clean bill of health from the dyno readings ? I have a used good stock valve body or other core parts I can offer.
I know these parts are not much to offer.. but money is on the tight side. If not acceptable please pm me what it would cost to install the vb on the dyno set pressure and check.
I am hoping that after putting it on the dyno and setting line pressure you will be able to give it a clean bill of health. Hoping to sell it after this work has been done.
If anyone wants to buy after I get a clean bill of health from Dr. John please let me know. Its a low band apply reverse pattern transbrake with a clean neutral. You can still use it without the clean neutral if you dont want or need a clean neutral VB
Thanks John
Jeff
Re: 727 Transbrake valve body [Re: jinxy] #2606745
01/15/19 01:22 AM
01/15/19 01:22 AM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
Adjusting the pressure is very easy. Let my dyno the vb set the pressure on the dyno and your lookn at 50 bucks. Joe's brother uses my valve body and services. So can you.
Re: 727 Transbrake valve body [Re: CRT] #2606768
01/15/19 02:34 AM
01/15/19 02:34 AM
MI
Jeff440sc Offline
Jeff440sc  Offline
MI
This is not a forum for selling race parts. Please place your for sale ads in the race parts or transmission parts for sale classifieds. Thank you.
Re: 727 Transbrake valve body [Re: jinxy] #2606893
01/15/19 01:19 PM
01/15/19 01:19 PM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
Just trying to help. Jeff it's free no charge.
Page 2 of 3 1 2 3
