Where to purchase carb parts that are not re-manufactured? #2603687
01/09/19 12:44 AM
01/09/19 12:44 AM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Anyone have a recommendation/contact where to purchase some Carter parts that I believe are not reproduced?
Some example of parts include the following:
1. Choke pull-off link rod
2. Fast idle cam rod link
3. Choke blade and shaft
4. Choke control link rod
5. Mounting lever/link control lever
Re: Where to purchase carb parts that are not re-manufactured? [Re: vinnyd76] #2603690
01/09/19 12:55 AM
01/09/19 12:55 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
carter had been making carbs since 1909. Might help if you mentioned what model. Edelbrock sells some linkage kits that might work
Don't be the exception.
Re: Where to purchase carb parts that are not re-manufactured? [Re: vinnyd76] #2603691
01/09/19 12:55 AM
01/09/19 12:55 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Parts carbs, swap meets, ads on forums like this one, eBay. I do it all the time, It can get expensive.
Re: Where to purchase carb parts that are not re-manufactured? [Re: ScottSmith_Harms] #2603698
01/09/19 01:10 AM
01/09/19 01:10 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
This !!
Re: Where to purchase carb parts that are not re-manufactured? [Re: vinnyd76] #2603706
01/09/19 01:32 AM
01/09/19 01:32 AM
I'd see if a yard has one (close enough to your year/model for parts interchange) for cheap. You might call John at "the carburetor shop", Google will provide the #, he has tons of em. By mail would be the most convenient (time is money).
Re: Where to purchase carb parts that are not re-manufactured? [Re: vinnyd76] #2603759
01/09/19 03:17 AM
01/09/19 03:17 AM
Alabama
BigMoneyLewis Offline
Alabama
I would guess a parts carb would be the way to go , as previously mentioned.
Just type in the number on ebay and try to find a clean core , as cheap as possible.
That's exactly what I have to do with the radio business, that's why I have over 1,000 A B E body radios over here for parts . Sometimes it is the only way to get that little part you need .
Greg
gregward@mchsi.com phone 256-852-0955
Re: Where to purchase carb parts that are not re-manufactured? [Re: Supercuda] #2603905
01/09/19 02:33 PM
01/09/19 02:33 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Small Block Carb: Carter 4934S
Re: Where to purchase carb parts that are not re-manufactured? [Re: vinnyd76] #2604079
01/09/19 08:07 PM
01/09/19 08:07 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Re: Where to purchase carb parts that are not re-manufactured? [Re: vinnyd76] #2604441
01/10/19 03:15 PM
01/10/19 03:15 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I buy parts from these guys
https://allcarbs.com/
Re: Where to purchase carb parts that are not re-manufactured? [Re: vinnyd76] #2604501
01/10/19 05:02 PM
01/10/19 05:02 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
If still open Benchwick in Youngstown Ohio had/has tons of carbs.They do nothing but rebuild and IIRC sell parts.Rocky
Chrysler Firepower
Re: Where to purchase carb parts that are not re-manufactured? [Re: vinnyd76] #2604628
01/10/19 09:09 PM
01/10/19 09:09 PM
Chicago
PurpleBeeper Offline
Chicago
fyi Edelbrock = Carter (Edelbrock purchased Carter to get into the carburetor business). I think buying a parts carburetor is your best option unless Edelbrock has all your little parts.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Where to purchase carb parts that are not re-manufactured? [Re: therocks] #2604759
01/11/19 01:31 AM
01/11/19 01:31 AM
London Ontario Canada
SYDWAZ Offline
SYDWAZ  Offline
Check out Walker Products in Missouri. Looks like they have new parts for every carb ever built.
Re: Where to purchase carb parts that are not re-manufactured? [Re: vinnyd76] #2604785
01/11/19 04:27 AM
01/11/19 04:27 AM
North Carolina
469runner Offline
469runner  Offline
North Carolina
I've had good luck here. The owner worked for Carter in St. Louis for years. Bought tons of NOS stuff when the factory was closed. http://thecarburetorshop.com/
Re: Where to purchase carb parts that are not re-manufactured? [Re: vinnyd76] #2604813
01/11/19 10:43 AM
01/11/19 10:43 AM
Sour Lake, Texas
61-63 Offline
61-63  Offline
Sour Lake, Texas
If Jon at the carbshop, or any of the others, can't help you pm me. I have boxes full of AFB components I used to restore them for people.
Re: Where to purchase carb parts that are not re-manufactured? [Re: 61-63] #2604888
01/11/19 01:07 PM
01/11/19 01:07 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Re: Where to purchase carb parts that are not re-manufactured? [Re: vinnyd76] #2604920
01/11/19 01:42 PM
01/11/19 01:42 PM
Alberta
rustbuckett68 Offline
Alberta
Think the rods are 1/8" rod which is easy to get. Can estimate the length and shape when following the FSM adjustments, and then a final tweak. Small hole for a pin, or a triangular file (or a fine saw blade)for a groove for the clips.
