Re: 1986 Dodge Ram Fitech installation
[Re: Moparmad]
#2604642
01/10/19 09:33 PM
01/10/19 09:33 PM
Posts: 20,627 in a cattle trailer down by th...
Guitar Jones
You could just wire up the relay and put it on a switch. Alternatively you could use two adjustable Hobbs switches and two relays plumbed into the governor port to get lockup.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Moparmad]
#2604789
01/11/19 05:17 AM
01/11/19 05:17 AM
Guitar Jones
If the converter is bad they usually lockup in reverse and stall the engine. Try driving it without the lockup hooked up first and see how it acts.
[Re: Moparmad]
#2604937
01/11/19 02:07 PM
01/11/19 02:07 PM
Posts: 2,042 colorado
savoy64
colorado
you can make your own lockup for the tranny---all you need is a on off pressure switch---pull one off a 80-90's chrysler AC unit---there is a diagram for it on line------basically the hot wire into the 2 plug lead--then the negative wire goes to the pressure port on the other side of tranny where the pressure switch is now installed---then up to your dash where you have an option if a toggle on/off---then ground back to the tranny....PATC has the diagram and explanation online....their switches are expensive----i usually just grab a few at the pick apart----on some foreign cars the same style of switches will actually have the BAR value printed right on them---the mopar AC switch works just fine...
[Re: savoy64]
#2605323
01/12/19 11:05 AM
01/12/19 11:05 AM
Guitar Jones
you can make your own lockup for the tranny---all you need is a on off pressure switch---pull one off a 80-90's chrysler AC unit---there is a diagram for it on line------basically the hot wire into the 2 plug lead--then the negative wire goes to the pressure port on the other side of tranny where the pressure switch is now installed---then up to your dash where you have an option if a toggle on/off---then ground back to the tranny....PATC has the diagram and explanation online....their switches are expensive----i usually just grab a few at the pick apart----on some foreign cars the same style of switches will actually have the BAR value printed right on them---the mopar AC switch works just fine... I tried doing this on my 92 that's been converted to lock up with less than stellar results. I had to use an adjustable Hobbs switch though as the governor pressure on a diesel is about twice what the gas engine version is. Anyway when the pressure would reach the trip point the lock up would hunt in and out if you couldn't keep accelerating past that point. Really annoying. Supercuda provided a wiring diaphragm that used two Hobbs switches set to high and low pressure points and two relays so that when the pressure reached the higher switch set point the converter would lock and then would stay locked until the lower pressure switch point was reached. Works like it's factory now. Locks up about 45+/- 1 or 2 MPH and unlocks about 40+/- 1 or 2 MPH.
[Re: Moparmad]
#2605381
01/12/19 02:07 PM
01/12/19 02:07 PM
savoy64
colorado
the pressure switch used by patc is a GM unit used in turbo 350 transmissions-----they charge about 20 times more for it than it costs-----the AC pressure switch turns on at 30 psi and turns off at 20psi (for instance)---this prevents the AC unit fluttering on and off at 25 psi and destroying the unit.....you can find a multitude of psi ranges available-----if you are wiring both lockup and overdrive you want to have the activation points at different spots.....i bought the patc kit for my 64 savoy with a 500 tranny---i was less that thrilled with trying to adjust the vacuum switch they provided---i run without it------i bought a 92 diesel truck with a bad o/d switch---it had been bypassed with just a toggle-----i put the purloined AC switch on it and drove it a year without issue.......
[Re: savoy64]
#2606033
01/13/19 06:17 PM
01/13/19 06:17 PM
Guitar Jones
Yeah that switch would work for overdrive but it's too low for lockup.
[Re: savoy64]
#2624085
02/21/19 05:04 AM
02/21/19 05:04 AM
Guitar Jones
27 to 31 for lockup isn't too bad in third. Probably still a little luggy depending on final drive ratio and all. But lockup at 27 to 31 in overdrive is a no go.
