Re: Aftermarket LCA pivot shaft diameter?
[Re: Greentween]
#2598782
12/30/18 01:54 PM
12/30/18 01:54 PM
Posts: 1,406 New Jersey, USA
yella71
New Jersey, USA
You seem to know the answer to your own question. yes I would think .020 is quite a bit smaller and if it comes loose it will cause problems. why are you using aftermarket arms? why don't you use your old piviot pins? it might be some extra work but might be worth the effort. that's my option only.
71 challenger convertable, 64 sport fury 383 ci with factory air
99 sebring convertable
89 CTD pup
[Re: Greentween]
#2598791
12/30/18 02:11 PM
12/30/18 02:11 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
What size is the hole in the K member? You may find that the OE pins were loose in the K member till you tighten the nut down as well.
