Re: will a '63 cross ram intake bolt up to 383 heads?
[Re: 61-63]
#2600840
01/03/19 10:48 AM
01/03/19 10:48 AM
Posts: 5,110 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
361-383 and 400 are B blocks that have a lower deck height which makes the intakes narrower... 413-426 and 440 are RB blocks which the crossram is designed to fit. Heads will interchange across the board with varying differences for individual part numbers... Mopar isn't anything like Pontiac as many individual engine parts do not interchange...
...FAFO...
[Re: 61-63]
#2600857
01/03/19 11:58 AM
01/03/19 11:58 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
63 cross ram what? Something like this? Or like this?
[Re: 61-63]
#2600871
01/03/19 12:18 PM
01/03/19 12:18 PM
Supercuda
About to go away
About to go away
up yours
Montclaire has it sorted then.
Otherwise, no.
[Re: 61-63]
#2600875
01/03/19 12:34 PM
01/03/19 12:34 PM
Posts: 7,982 Scranton, PA
Montclaire
Scranton, PA
He's kinda stuck either way. Unless he can find a super deal, the heads are going to cost big bucks. He might be better off selling the 383 and the intake, and buying a core 440 and an A&A crossram with regular ports.
In most cases it's not worth bothering with a 413 or 426 wedge because (unless things have changed) pistons aren't readily available and will set you back a mint. A basic 440 with quality parts and something lumpy like a 509 cam and twin 500s would be a nice combination.
[Re: 62maxwgn]
#2600926
01/03/19 02:03 PM
01/03/19 02:03 PM
Supercuda
About to go away
About to go away
up yours
The question was,will the intake bolt to the "heads",nothing said about the block. Did you miss the third post in the thread or were you in such a hurry to show how smart you are you stopped at the second post? What block and heads could I use? Just saying...
[Re: 61-63]
#2600933
01/03/19 02:10 PM
01/03/19 02:10 PM
Posts: 4,693 Wichita
GY3
Wichita
Guys I don't have anything right now but several sets of 3705 carbs; no car, no engine, no intake, no nothing. If I do this, and likely won't but thinking about it anyway, I will try to get a car that already has the engine and heads, and if not then get a 440 block and set of Edelbrock max wedge aluminum heads, and go with that.
I'm just pie in the skying here and taking notes. If you're going just for the look I would suggest buying the A&A reproduction cross ram that has 440 size ports and putting one on top of a 440. Will look virtually the same and only hardcore guys will know the difference.
[Re: Supercuda]
#2601006
01/03/19 04:29 PM
01/03/19 04:29 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
The question was,will the intake bolt to the "heads",nothing said about the block. Did you miss the third post in the thread or were you in such a hurry to show how smart you are you stopped at the second post? What block and heads could I use? Just saying... About what I would expect !!
[Re: 61-63]
#2601047
01/03/19 06:20 PM
01/03/19 06:20 PM
skicker
"The Champ"
"The Champ"
Western Md.
Don't lose any sleep over it Bill... Everything is bigger in Texas... SuperCuda it's obvious you have some knowledge...quit acting like your on Y/B...after a while it gets old... just sayin...
...FAFO...
