Re: LED Dome Light - Stays On?
[Re: njmopar]
#2600222
01/01/19 11:15 PM
01/01/19 11:15 PM
Posts: 15,299 Omaha Ne
TJP
Omaha Ne
What year model etc. Most of the 60-70"s cars used a dual contact bulb and the door switches as a ground to complete the circuit to the second contact. Battery power was present at the positive contact all the time. Might also want to check the orientation of the contacts to the side pegs between bulbs. If they are off it could cause a short between the contacts.
[Re: stumpy]
#2600401
01/02/19 01:14 PM
01/02/19 01:14 PM
Posts: 19,342 north of coder
moparx
Dumb question but have you tried reversing the bulb. there are quite a few LED's out there that are polarity specific. i ran into that just the other day with a third brake light setup. it sounds goofy, but before you start anything, just turn bulb 180* and re-insert. not saying this will work, but it has for me plenty of times with LED's.
[Re: Mopar72Man]
#2600421
01/02/19 01:56 PM
01/02/19 01:56 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
The normal on led bulbs is they are polarity specific... indeed they are diodes.
if its turning on, is indeed on correct polarity, JUST maybe is not using the correct led bulb replacement.
asuming is an old Mopar which uses the 1004 bulb, needs to be sure you are getting the correct bulb replacement with filaments/emissors isolated from socket and just getting both poles throught the contacts on base. NOT ANY 2 CONTACTS BULB WILL WORK!!! 1057 bulbs for example seems to work being dual contacts BUT NOT! they get ground by the socket and the socket on dome light is attached to the body, so ANY of the contacts getting positive will make it light up and won't turn off ever being, as described previouslly, the dome light is switched on/off via negative/Ground and positive being constant from batt!
[Re: NachoRT74]
#2600428
01/02/19 02:11 PM
01/02/19 02:11 PM
moparx
you are correct nacho ! i FORGOT about the ground circuit being in the bulb socket. [oldtimer's disease AGAIN !] so now, it's time to find out where the power is coming from. it is possible the contact inside the socket is twisting when the bulb is being inserted, or possibly the headlight switch is shorted internally ?
[Re: Mopar72Man]
#2600436
01/02/19 02:32 PM
01/02/19 02:32 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
If your car has a light timer on the dome light that can cause the light staying on with the LED, because the led does not put enough load on the circuit to heat up the timer.
[Re: Mopar72Man]
#2600482
01/02/19 04:01 PM
01/02/19 04:01 PM
Posts: 25,747 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If you put a single-contact bulb in a IOD powered dual-contact socket, the light will stay on continuously. (grounds through the socket instead of the door switch)
[Re: Mopar72Man]
#2601024
01/03/19 05:15 PM
01/03/19 05:15 PM
Posts: 3,358 Berwyn, IL
challenger70
Berwyn, IL
I have a LED dome light (just replacement bulb) that will still come on once or twice with the battery (ground side) disconnected. It's faint and if I close and reopen the door it will stay completely out. It does work normally otherwise though. I will try reversing it.
[Re: challenger70]
#2601330
01/04/19 03:33 AM
01/04/19 03:33 AM
Posts: 270 Missouri
Big_E
Missouri
I had a problem with the LED dome light in my 69 RR. Your light is staying on. Mine blew a fuse and toasted my dimmer switch. Turned out it was a problem with the bulb. See this link here, next to the bottom post; LED Hope you get yours figured out.
