Re-manufactured Transmission Quality? #2599415
12/31/18 08:29 PM
12/31/18 08:29 PM
Cruising!
Q
QuickDodge Offline OP
Q
Cruising!
I'm dealing with a 2004 Sebring that needs a transmission. It's has the 3.0 engine, automatic transmission. It is a somewhat trouble prone Mitsubishi transmission. It was only used for 2 or 3 years, so finding one is proving difficult.
Advance Auto Parts and Auto Zone have rebuilt transmissions for $1600 - $1800. I believe the transmission from Advance has a 3 year, 75,000 mile warranty. Does anyone have any thoughts on the quality and durability of these re-manufactured transmissions.
Re: Re-manufactured Transmission Quality? [Re: QuickDodge] #2599458
12/31/18 09:14 PM
12/31/18 09:14 PM
A727Tflite Online content
A727Tflite  Online Content
Find someone that sells a Jasper or Certified Transmission unit.
Re: Re-manufactured Transmission Quality? [Re: QuickDodge] #2599541
12/31/18 11:16 PM
12/31/18 11:16 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We used a few from Advanced at the shop.Never had a problem.IIRC they were remaned by a major company.Cheaper because they order a lot.Rocky
Chrysler Firepower
Re: Re-manufactured Transmission Quality? [Re: QuickDodge] #2599605
01/01/19 02:06 AM
01/01/19 02:06 AM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Can't speak for yours, but a friend bought a reman 46RE from advanced and didn't have a problem for the 3ish years he kept it. I wouldn't be afraid to go that route...
Re: Re-manufactured Transmission Quality? [Re: QuickDodge] #2600260
01/02/19 01:20 AM
01/02/19 01:20 AM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
It’s “Advance”, not Advanced wink. I work part-time there, I’ve not seen any transmissions returned.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: Re-manufactured Transmission Quality? [Re: QuickDodge] #2600274
01/02/19 01:42 AM
01/02/19 01:42 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
One thing I will mention is that in my experiance, is that the biggest reasons for failure of a reman unit, is a clogged, or dirty cooler in the radiator. If you do not flush your cooler with the proper equipment or replace the radiator, it will destroy your new trans, no matter who built it. I used to do bench overhauls for a couple local shops, I no longer so because the shops refused to buy decent flushing equipment. Blowing lines with an air hose is not flushing a cooler.
Re: Re-manufactured Transmission Quality? [Re: QuickDodge] #2600423
01/02/19 01:57 PM
01/02/19 01:57 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
I put one of Advance Auto Parts remanufactued transmissions in my Dodge Diplomat years ago. It worked great and still does. I think it was an 999 with the lockup convertor.
Re: Re-manufactured Transmission Quality? [Re: QuickDodge] #2600489
01/02/19 04:13 PM
01/02/19 04:13 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
We have had ok luck with autozone remans. Dodge rwd trannys I re-build my own self and am shocked at what I see in the ones marked mopar reman. I commonly see the wrong planetariums and wrong number of clutches in those like the diesel ones getting lighter duty gas parts probably because they just had them sitting around in the factory, it is no wonder they got such a reputation as bad trannys, the re-mans dont last as long as the factory ones and the factory ones usually fail as a result of bad maintenance. The auto zone ones probably last longer as they put the right stuff in them because they dont just have stuff laying around.
