2009 P0440 Evap recover general failure
#2599365
12/31/18 07:14 PM
12/31/18 07:14 PM
Posts: 1,453 WV
bacaruda
WV
Ok replaced cap, no help, now what is most likely to go for next? I have printed 20pgs or so from my TechAuthority CD and AllData. But need to know what is most likely the issue before wasting time and finding the problem last.
Much appreciated!
Jim.
Oh, yeah, RAM 1500 5.7, 4WD, auto.
Re: 2009 P0440 Evap recover general failure
[Re: bacaruda]
#2599368
12/31/18 07:18 PM
12/31/18 07:18 PM
Posts: 20,183 Park Forest, IL
slantzilla
Park Forest, IL
I just had my PT in for the same thing today. Turned out to be a crack in the evap canister.
[Re: bacaruda]
#2599397
12/31/18 08:19 PM
12/31/18 08:19 PM
Posts: 25,842 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Mine turned to be a leaking ESIM, only found by doing a smoke check.
[Re: 64hemi330sedan]
#2599587
01/01/19 01:33 AM
01/01/19 01:33 AM
Posts: 1,908 Nebraska
4406bbl
Nebraska
my 14 1500 has the same problem. took it to the dealer. paid for a hour of check out and had it smoke tested. found rodent damage to the vent line that goes to the purge valve. its not covered under warranty.$998.65 to fix it. the line is part of the fuel tank. so I took it home and I am going to splice the line with rubber hose to fix it. thank god I have a lift. it will make the job a lot easier. Believe it or not most insurance companies pay for proven rodent damage. You need to decide if it is worth turning in or not. I would wipe some dino oil or something on the lines and wiring. I saw one where squirrels ate the line, part of the nipple on the valve and the wiring, guy turned it in and his insurance paid for it.
[Re: bacaruda]
#2602379
01/06/19 12:40 PM
01/06/19 12:40 PM
Posts: 13,601 md
mopars4ever
md
my 14 1500 has the same problem. took it to the dealer. paid for a hour of check out and had it smoke tested. found rodent damage to the vent line that goes to the purge valve. its not covered under warranty.$998.65 to fix it. the line is part of the fuel tank. so I took it home and I am going to splice the line with rubber hose to fix it. thank god I have a lift. it will make the job a lot easier. Last week my daughter said her car wasn`t running well and the check engine light came on. I found the wire to the O2 sensor was completely chewed through in two places.
