Re: Is manually shifting a 727 bad?
[Re: dvw]
#2598958
12/30/18 09:37 PM
12/30/18 09:37 PM
Posts: 12,157 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
The thrust washers between the input and output shafts. I have seen them beat out bad enough to keep the clutch pack from pressuring up. And every time I have seen it, it is in a car that the guy lifts between the 1-2 shift. All the slack goes one way, then it is slammed the other way.
Not something you see much when normal forward thrust is maintained when shifting whether manual or auto. But something that can and will happen with certain types of abuse.
I have seen it often enough that I always use A&A's Torrington bearing in there.
The 2-3 overlap is caused by both the clutch pack and the band trying to hold at the same time. Something has to give and additional wear is unavoidable. It is usually the clutches that wear the most until there is enough additional clearance that slows clutch application and causes a flair.
Master, again and still
[Re: SportF]
#2600066
01/01/19 07:58 PM
01/01/19 07:58 PM
Posts: 10,588 Freeport IL USA
poorboy
Freeport IL USA
Why do you have a car?
Why don't you drive it like a drag racer? If it breaks, fix it.
If having fun with your car is too hard on it, park it. Then you'll never have to fix it.
Do you want to save it for the next guy? DO you go to your grave knowing that you could have had fun, but by gosh those thrust washers and rear band are still in great shape!
I find this one of these amazing and amusing questions, one that shows up here with some regularity.
See you in the funny papers. The thing that gets me is the floor mats and the seat covers that are never removed. What are people saving this stuff for? Often the seats and the carpet look great in the Pull A Part until some fool throws some greasy part on them. Gene
