MSD ignition vs Mallory for 72 340 which is better ?. #2598110
12/28/18 07:40 PM
12/28/18 07:40 PM
Bradford, Ontario
Barrelhouse Offline OP
Bradford, Ontario
Hello everyone i hope you all had a great Christmas. Im thinking of replacing my stock ignition system with a quality after market kit. My 340 will be making 400 to 450 HP. I want a reliable street car that i can drive daily in the nice weather it has to be something that will be well suited for my engine what do you guys think is better MSD or Mallory ?, thanks for any input.
Re: MSD ignition vs Mallory for 72 340 which is better ?. [Re: Barrelhouse] #2598118
12/28/18 08:10 PM
12/28/18 08:10 PM
Planet Earth
RoadRunnerLuva Offline
Planet Earth
I use a Mallory billet distributor, a Rev-N-Nator ignition box, and a MSD
Blaster 2 coil, on my 418 c.i. Duster, car runs like a raped ape chasing a banana boogie
Plymouth Makes It!
Re: MSD ignition vs Mallory for 72 340 which is better ?. [Re: Barrelhouse] #2598125
12/28/18 08:32 PM
12/28/18 08:32 PM
md
mopars4ever Offline
mopars4ever  Offline
md
All MSD on my 360. Never had a issue and always fires right up.
Re: MSD ignition vs Mallory for 72 340 which is better ?. [Re: Barrelhouse] #2598141
12/28/18 09:32 PM
12/28/18 09:32 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Myself,
factory electronic, a good coil and be done with it. Parts are easy to get should you need them and reasonably priced.
twocents
Re: MSD ignition vs Mallory for 72 340 which is better ?. [Re: Barrelhouse] #2598200
12/28/18 11:54 PM
12/28/18 11:54 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I run the MSD Streetfire with the MSD vibration coil, and a FBO distributor. No problems with the MSD units in three years.
Re: MSD ignition vs Mallory for 72 340 which is better ?. [Re: TJP] #2598224
12/29/18 01:44 AM
12/29/18 01:44 AM
OE electronic dist (dial it in). HEI module mounted under the dist. furd E coil (dirt cheap at rockauto), dont have the # offhand. Is your current curve dialed in?
Re: MSD ignition vs Mallory for 72 340 which is better ?. [Re: Barrelhouse] #2598225
12/29/18 01:55 AM
12/29/18 01:55 AM
Cab_Burge Online work
Cab_Burge  Online Work
I've ran and raced with MSD ignition for a long time, I'm a firm believer in using better parts than you currently need so I would say go with the MSD box and coil for the box you decide to use up
I ran the big gold race boxes (404B,404C,7,7C 7A and the current MSD7AL2 with the proper coils on all of them up) on my serious street cars devil
On your deal a MSD6AL would be my pick with your current stock ECU coil up scope Follow the directions for wiring it and the coil also thumbs
Re: MSD ignition vs Mallory for 72 340 which is better ?. [Re: Cab_Burge] #2598362
12/29/18 01:49 PM
12/29/18 01:49 PM
Halifax, VA.
moparjack44 Offline
moparjack44  Offline
Halifax, VA.
I ran Mallory for several years in my 1st Gen 392 Hemi. Kept having faliures, replace with MSD, elminated any box, no problems. Very happy with the MSD.
K.I.S.S.
Re: MSD ignition vs Mallory for 72 340 which is better ?. [Re: Barrelhouse] #2598891
12/30/18 06:51 PM
12/30/18 06:51 PM
Washington
madscientist Offline
Washington
Find a used Mallory digital 6 box, number 685 and buy the correct coil for it and be done. It will run forever.
I have several on the shelf but none for sale. I buy all I can at swap meets for pennies on the dollar. Bought an analog 7 box with coil, a two step and two stage retard for 80 bucks. Already tested good.
80 bucks because it didn't say MSD. All the better for me.
