Re: 62-65 speedo gears [Re: Bull1tt] #2597867
12/28/18 02:51 AM
12/28/18 02:51 AM
^^^ trick!
Re: 62-65 speedo gears [Re: Charrlie_S] #2598043
12/28/18 04:36 PM
12/28/18 04:36 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Originally Posted By Charrlie_S
I've never looked that close to see if it could be done, but.
Would it be possible to use the stock speedo trans gear/cable assy, and put the ratio adapter on the other end of the cable, then have a short cable to connect the ratio adapter to the speedo head? Similar to the way mopar did the cruise control.
Yes, they make inline reducers that have threaded input/output or crimp in the cable. Speedo shops use them to get the cable speed dead on when there's no room at the trans output.
Here's a nifty idea to keep the stock speedo and drive it with a GPS input.
https://www.speedhut.com/ecommerce/product/2585/SPEEDBOX™-GPS-VSS-to-Mechanical-Drive-Speed-Converter
Re: 62-65 speedo gears [Re: viperakron] #2598143
12/28/18 09:33 PM
12/28/18 09:33 PM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
Use the link three post up...
Re: 62-65 speedo gears [Re: Bull1tt] #2598187
12/28/18 11:28 PM
12/28/18 11:28 PM
bought used/never tried it. Stewart Warner made in US of A.
Re: 62-65 speedo gears [Re: RapidRobert] #2598191
12/28/18 11:32 PM
12/28/18 11:32 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
What ratio is that one? They made hundreds of different ones.
Re: 62-65 speedo gears [Re: John Brown] #2598197
12/28/18 11:50 PM
12/28/18 11:50 PM
It has 1.2020X stamped
Re: 62-65 speedo gears [Re: RapidRobert] #2603434
01/08/19 02:42 PM
01/08/19 02:42 PM
I opened it up & the teeth count is (in to out/upper left to lower right): 11 teeth/18 teeth on the middle idler/14 teeth. EDIT I ain't sure if this (procedure) is right but 11/18 is .61111 and 18/14 is 1.28511 and 1.28511-.61111 = .6746 (underdriven???). MORE EDIT With more work if my math is right it will reduce the tooth count 27.27%, speeding up the speedo that % amount
