Re: 62-65 speedo gears
[Re: viperakron]
#2597317
12/26/18 10:08 PM
12/26/18 10:08 PM
Posts: 21,050 Niles , Ohio
therocks
Niles , Ohio
I run the OE 3.23 gear gear in my 65.Now has 3.91s i know that speedo is about 20% fast.Just compensate for it.It was way off when i ran 4.88s on the street.Also the gears are different than later models which makes them even harder to find.Rocky
Chrysler Firepower
[Re: viperakron]
#2597366
12/27/18 12:04 AM
12/27/18 12:04 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Problem is where do you get a ratio reducer. I used to know a speedo shop that I got new cables for my 64 300 from that could make them, but that was in 1988. Now days, who knows?
[Re: lewtot184]
#2597367
12/27/18 12:06 AM
12/27/18 12:06 AM
RapidRobert
a 20 tooth with a 3.73 rear by itself won't be accurate. any axle ratio lower (higher numerically) than a 3.55 will require a ratio reducer. there was never any combo's made that was perfectly accurate. the easiest way is a 17 tooth with a .80 ratio reducer. 19 and 20 tooth were used mostly in 3.23 gear cars. 21 tooth was for 3.55 rear and 3.91 gear cars used a 21 tooth with a .80 reducer. I use an 18 tooth with a .90 reducer for a 3.23 gear and 28" tall tires. speedo is close but not perfect. Lewt good info (I gotta a couple of early ones up coming)
[Re: viperakron]
#2597476
12/27/18 09:52 AM
12/27/18 09:52 AM
Posts: 3,913 usa
lewtot184
usa
I got my reducer from Imperial Services years ago, but I think they're out of business now. the Good Guys Gazette had a speedo service ad for odd stuff but I haven't gotten the gazette in a few years. I was told that they were used on Fargo truck stuff. maybe goggle them? they're the only solution.
I found this in an older gazette. United Speedometer Service, Inc. 951-684-0292. give them a call. a stock cable won't work with the reducer, but a 1966 cable will.
[Re: lewtot184]
#2597535
12/27/18 01:06 PM
12/27/18 01:06 PM
Supercuda
About to go away
About to go away
up yours
I found this in an older gazette. United Speedometer Service, Inc. 951-684-0292. give them a call. a stock cable won't work with the reducer, but a 1966 cable will. Don;t think that phone number is accurate anymore. http://www.usande.com/contact.htmlI think they may have been the one I dealt with way back when.
[Re: Prodart440]
#2597693
12/27/18 07:13 PM
12/27/18 07:13 PM
Posts: 25,618 Rio Linda, CA
John_Kunkel
Rio Linda, CA
No, they're thread-on adapters, the '62-'65 uses this type.
[Re: viperakron]
#2597764
12/27/18 09:53 PM
12/27/18 09:53 PM
Posts: 63 Silver Springs, Florida
Charrlie_S
I've never looked that close to see if it could be done, but. Would it be possible to use the stock speedo trans gear/cable assy, and put the ratio adapter on the other end of the cable, then have a short cable to connect the ratio adapter to the speedo head? Similar to the way mopar did the cruise control.
Charrlie_S 66 Cuda 170 nitrous 66 Valiant 225 nitrous 65 Valiant 170 turbo 64 Valiant driver 64 Valiant roller
[Re: viperakron]
#2597775
12/27/18 10:24 PM
12/27/18 10:24 PM
Supercuda
About to go away
About to go away
up yours
Sure, it could be done. Need two custom cables though that's the easy part.
