Re: Mild 440 Cam Choice
[Re: moparpaul66]
#2593776
12/18/18 03:03 PM
12/18/18 03:03 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
That cam should work fine in that combo.
Was it degreed in?
Have you done a cranking compression test?
Any blending done to the heads after the big valves were put in? They often flow less than stock if not, depending on exactly how the bowl cut/transition was done.
Off the top of my head, it really just looks like it could use more stall.
[Re: moparpaul66]
#2593777
12/18/18 03:04 PM
12/18/18 03:04 PM
crabman173
crabman173
The best one IMO is the Summit Racing K6401 Install it around 104 and you will be happy camper and ...it is cheap as dirt I have used about 50 of them over the years--perfect entry level TQ cam that will giddy up nicely --sounds decent and makes a tire melter out of a low compression 440 --anything else in that application is lots more $$$$$ and IMO not any better In that wagon maybe even go 103 on install CL Thing is you have everything in place for a hot 440 EXCEPT compression so it is the limiting factor--so shave heads about -040 or swap to the 6401 cam installed like mentioned a 3/4 ton car is hard to get moving
[Re: moparpaul66]
#2593804
12/18/18 03:32 PM
12/18/18 03:32 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
906 heads with larger valves, eddy rpm intake, AVS 800 carb, 1 3/4 headers, going in a 68 Satellite Wagon with 2500 stall and 4.10's.
The XE274 is OK but spongy on the bottom end. Sugguestions? Thanks!
Please describe further what you mean by "spongy" and under what conditions is it spongy? WOT from a stop? Part throttle from a stop? Part throttle at low speed cruise?....... Is it already in the Satellite? Was it in something else before? If so, what?
[Re: moparpaul66]
#2593812
12/18/18 03:42 PM
12/18/18 03:42 PM
Posts: 17,892 S.E. Michigan
ZIPPY
S.E. Michigan
Initial timing? Advance all in at or below stall speed?
Rich H.
Esse Quam Videri
[Re: polyspheric]
#2593949
12/18/18 08:36 PM
12/18/18 08:36 PM
Posts: 184 Memphis,TN
J. Hammer
Memphis,TN
it could use more stall Yes Can't they all? I'll JWAG whats up with the distributor curve?
[Re: 451Mopar]
#2593987
12/18/18 10:24 PM
12/18/18 10:24 PM
BSB67
Prospect, PA
I don't see an issue with that cam either. I'd look at the tuning, ignition advance curve to start with. Same. That's why i asked what spongy is to the OP. It could be due to a cheap a** converter under part throttle conditions. Nothing about that combination should be spongy when you drop the hammer. Even if it had a stock converter and 3.23s. But it is a relative.discussion. Maybe the OP is use to a 1.5 sec. 60ft in street trim?
[Re: BSB67]
#2594023
12/18/18 11:43 PM
12/18/18 11:43 PM
RapidRobert
What Dwayne said, do a compression test & post what your timing numbers are to try & pin it down to either an eng prob or converter (not my area) problem or something else (gear ratio or ???).
[Re: moparpaul66]
#2594119
12/19/18 04:57 AM
12/19/18 04:57 AM
Posts: 16,479 Canada
CrAzYMoPaRGuY
Canada
I have a 440 that is also exactly 9.35 to 1 compression. I run a 270H Comp Cam and a CH28 with two Edelbrock 500s, 18 initial, 36 total. I love it.
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#2594138
12/19/18 07:18 AM
12/19/18 07:18 AM
Posts: 2,867 Pattison Texas
CSK
Pattison Texas
I have a 440 that is also exactly 9.35 to 1 compression. I run a 270H Comp Cam and a CH28 with two Edelbrock 500s, 18 initial, 36 total. I love it. I would bet it would run better with more initial. even though it runs good now.
[Re: moparpaul66]
#2594199
12/19/18 12:48 PM
12/19/18 12:48 PM
fast68plymouth
So. Burlington, Vt.
My guess is you’d find better idle and very low speed driveability with a carb that has 4 corner idle.
You should look into something like a TCI Breakaway converter. A TA “hemi” converter would be great, but I don’t think they’re still available, although it’s probably worth a phone call.
However, If I was determined to change the cam to try and improve the overall bottom end performance, and not take noticeable a power hit in the process...... I’d put a Crower 271hdp in it.
[Re: moparpaul66]
#2594290
12/19/18 03:46 PM
12/19/18 03:46 PM
CSK
Pattison Texas
Bump the initial timming up to 24 & drive it easy, see how it runs, if it likes it get the dist recurved to match.
[Re: CSK]
#2594335
12/19/18 05:43 PM
12/19/18 05:43 PM
RapidRobert
Agreed on the timing bump (& it is easy to do/reverseable). I had 19 on a bone stock 318 that was at 15 (just from adv the cam 4 deg) & I did not change the springs/reduce the total. started/idled fine.
[Re: moparpaul66]
#2594406
12/19/18 08:00 PM
12/19/18 08:00 PM
Posts: 5,164 CT
GTX MATT
CT
What kind of distributor?
[Re: moparpaul66]
#2594661
12/20/18 01:18 PM
12/20/18 01:18 PM
fast68plymouth
So. Burlington, Vt.
If it actually flashed to 3k(not 3400, 3600, 3800, etc), and was a quality piece, for a 230@.050 cam in that combo....... it should be fine.
