Re: Mopar Electronic Ignition ICU box recommendation? [Re: 70gtx440dana] #2592095
12/14/18 10:42 PM
12/14/18 10:42 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I've got a Pertronix in a 528 that is nothing, but a street car, never missed a beat.
Re: Mopar Electronic Ignition ICU box recommendation? [Re: 70gtx440dana] #2592098
12/14/18 10:45 PM
12/14/18 10:45 PM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: Mopar Electronic Ignition ICU box recommendation? [Re: 70gtx440dana] #2592164
12/15/18 01:46 AM
12/15/18 01:46 AM
Stevensville, ON
Frank Raso Offline
Frank Raso  Offline
Stevensville, ON
The designed to drive HEI bracket looks clean but I think you're better off mounting the HEI module off the engine and on a heat sink to keep it cooler.
I upgraded from a Mopar Orange Box to a GM HEI system this summer and I like the HEI's ability to ignite a leaner fuel mixture. See HEI Ignition Upgrade.
Re: Mopar Electronic Ignition ICU box recommendation? [Re: 70gtx440dana] #2592411
12/15/18 04:25 PM
12/15/18 04:25 PM
VA
dragon slayer Offline
VA
Frank, Thanks for the work you did on your website. Very informative and got some good links to other site that google did not surface!
Re: Mopar Electronic Ignition ICU box recommendation? [Re: dragon slayer] #2592426
12/15/18 05:22 PM
12/15/18 05:22 PM
Land 'O Lakes
RoadRunnerLuva Offline
Land 'O Lakes
I have an orange Rev-N-nator on my Duster, and I also like the rev limit feature it has.
Plymouth Makes It!
Re: Mopar Electronic Ignition ICU box recommendation? [Re: RapidRobert] #2592448
12/15/18 06:17 PM
12/15/18 06:17 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Originally Posted By RapidRobert
20 years ago, Dr. Chris Jacobs in his guide to electronic ignitions said the Standard LX-101 was about as good as it got without buying one of his units. If you decide to go this route keep in mind that Standard Motor Products has two lines, the regular and the "T" series. The T series is their budget or "Thrift" line. R.
I have that book. a good read. I think back then that LX was American made but now it is made in china.
as far I know, Don from 4secondsflat stop making the A688 FBO module because they were made by Standard per request under his specs, but when they moved the production to China began the quality issues so he stop to produce them. Shame because they were GREAT units. Maybe my only 6 months working unit was one of those ? can't tell
Re: Mopar Electronic Ignition ICU box recommendation? [Re: NachoRT74] #2592579
12/15/18 11:49 PM
12/15/18 11:49 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
His web site now says this: Modern Electronics and engineering using the most modern components available and Engineered, Designed, Manufactured and Assembled IN THE USA
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
Re: Mopar Electronic Ignition ICU box recommendation? [Re: 70gtx440dana] #2593031
12/17/18 02:04 AM
12/17/18 02:04 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Yes, that's for the new units, but I'm talking about the OLD stock look A688 unit
Re: Mopar Electronic Ignition ICU box recommendation? [Re: 70gtx440dana] #2593146
12/17/18 02:22 PM
12/17/18 02:22 PM
Colorado front range
BcudaChris Offline
BcudaChris  Offline
Yeah, the new one is HRR688
Re: Mopar Electronic Ignition ICU box recommendation? [Re: 70gtx440dana] #2593272
12/17/18 05:59 PM
12/17/18 05:59 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
And there was an intermediate model called HR688 which it was the aluminium box with an HEI module hidden inside.
Re: Mopar Electronic Ignition ICU box recommendation? [Re: 70gtx440dana] #2593858
12/18/18 04:52 PM
12/18/18 04:52 PM
BcudaChris Offline
BcudaChris  Offline
Having dealt with Don, I can assure you it would have been a MADE IN USA HEI module.
