440 Main Bearings
#2591412
12/13/18 05:34 PM
12/13/18 05:34 PM
Posts: 1,505 TN
SCATPACK 1
TN
Is there a company that still makes a full groove Main Bearing set for a 440 or Hemi mains? Spent some time with the NAPA parts guy and did not find anything that had full grooves. 3/4 and half grooves is all we could find. I want to use the full groove set if possible to take advantage of full time oiling to the rod bearings. Any Mfg or part numbers would be greatly appreciated.
Old Geezer Racing
Re: 440 Main Bearings
[Re: SCATPACK 1]
#2591445
12/13/18 07:00 PM
12/13/18 07:00 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Clevite Enginetech The Mancini ones linked are for the early thrust diameter blocks. The ones I linked are for the later, larger diameter thrust.
[Re: ZIPPY]
#2591449
12/13/18 07:11 PM
12/13/18 07:11 PM
Supercuda
About to go away
About to go away
up yours
Small diameter thrust bearing. You can use them in the later blocks but you give up some thrust bearing capacity.
[Re: Supercuda]
#2591501
12/13/18 09:09 PM
12/13/18 09:09 PM
Posts: 25,747 Rio Linda, CA
John_Kunkel
Rio Linda, CA
OP didn't state the year of his block.
[Re: Supercuda]
#2591503
12/13/18 09:14 PM
12/13/18 09:14 PM
Posts: 1,505 TN
SCATPACK 1
TN
Clevite Enginetech The Mancini ones linked are for the early thrust diameter blocks. The ones I linked are for the later, larger diameter thrust. SuperCuda, Have you had any experience with the Aluminum bearings that Engine Tech refers to?
Old Geezer Racing
[Re: John_Kunkel]
#2591504
12/13/18 09:16 PM
12/13/18 09:16 PM
Posts: 1,505 TN
SCATPACK 1
TN
OP didn't state the year of his block. You are correct John I did not. I have a 72 and a 73 and a 74 440 block to choose from. I am thinking the 72 is a better block just based on how it has been stored the last 20 years. The other 2 blocks are showing some rust in the cylinder walls.
Old Geezer Racing
[Re: John_Kunkel]
#2591541
12/13/18 10:48 PM
12/13/18 10:48 PM
Supercuda
About to go away
About to go away
up yours
OP didn't state the year of his block. True, which is why I pointed out the differences, didn't know if he was aware. As I mentioned, you can use the early style in the later blocks, but lose some thrust capacity. Will that matter? Chrysler thought so at the time.
[Re: SCATPACK 1]
#2591543
12/13/18 10:51 PM
12/13/18 10:51 PM
Supercuda
About to go away
About to go away
up yours
Nope, last time I built an RB I used Clevite 77's and we had to buy two sets to get full main grooves.
[Re: SCATPACK 1]
#2591553
12/13/18 11:01 PM
12/13/18 11:01 PM
Posts: 1,505 TN
SCATPACK 1
TN
Well Riddle me this Brad, or Zippy, or Super Cuda or John. I can not remember for certain. So what year did they go to the larger thrust bearing surface? I wan't to think it was in 72 with the introduction of the 400 block, but again, I am not completely certain. Thanks again for each and everyone's help in my search. Merry Christmas Jerry
Old Geezer Racing
[Re: Supercuda]
#2591579
12/14/18 12:02 AM
12/14/18 12:02 AM
Posts: 1,505 TN
SCATPACK 1
TN
Well. I was really off on what I thought. thanks for clearing my memory up for me Super Cuda.
Old Geezer Racing
