Re: Mopar Electronic Ignition ICU box recommendation?
[Re: 70gtx440dana]
#2592164
12/15/18 01:46 AM
12/15/18 01:46 AM
Posts: 74 Stevensville, ON
Frank Raso
Stevensville, ON
The designed to drive HEI bracket looks clean but I think you're better off mounting the HEI module off the engine and on a heat sink to keep it cooler. I upgraded from a Mopar Orange Box to a GM HEI system this summer and I like the HEI's ability to ignite a leaner fuel mixture. See HEI Ignition Upgrade.
[Re: dragon slayer]
#2592426
12/15/18 05:22 PM
12/15/18 05:22 PM
Posts: 5,389 Planet Earth
RoadRunnerLuva
Planet Earth
I have an orange Rev-N-nator on my Duster, and I also like the rev limit feature it has.
Plymouth Makes It!
[Re: RapidRobert]
#2592448
12/15/18 06:17 PM
12/15/18 06:17 PM
Posts: 6,109 Valencia, España
NachoRT74
Valencia, España
20 years ago, Dr. Chris Jacobs in his guide to electronic ignitions said the Standard LX-101 was about as good as it got without buying one of his units. If you decide to go this route keep in mind that Standard Motor Products has two lines, the regular and the "T" series. The T series is their budget or "Thrift" line. R. I have that book. a good read. I think back then that LX was American made but now it is made in china. as far I know, Don from 4secondsflat stop making the A688 FBO module because they were made by Standard per request under his specs, but when they moved the production to China began the quality issues so he stop to produce them. Shame because they were GREAT units. Maybe my only 6 months working unit was one of those ? can't tell
[Re: NachoRT74]
#2592579
12/15/18 11:49 PM
12/15/18 11:49 PM
Posts: 315 Ontario, Canada
RealWing
Ontario, Canada
20 years ago, Dr. Chris Jacobs in his guide to electronic ignitions said the Standard LX-101 was about as good as it got without buying one of his units. If you decide to go this route keep in mind that Standard Motor Products has two lines, the regular and the "T" series. The T series is their budget or "Thrift" line. R. I have that book. a good read. I think back then that LX was American made but now it is made in china. as far I know, Don from 4secondsflat stop making the A688 FBO module because they were made by Standard per request under his specs, but when they moved the production to China began the quality issues so he stop to produce them. Shame because they were GREAT units. Maybe my only 6 months working unit was one of those ? can't tell His web site now says this: Modern Electronics and engineering using the most modern components available and Engineered, Designed, Manufactured and Assembled IN THE USA
1970 Superbird 440-6bbl, auto 1969 Barracuda 340-4bbl, FB Formula S auto 1969 Barracuda 6.1 L Hemi, 5 speed, Convertible 2022 Can Am Spyder RTL
[Re: 70gtx440dana]
#2593031
12/17/18 02:04 AM
12/17/18 02:04 AM
NachoRT74
Valencia, España
Yes, that's for the new units, but I'm talking about the OLD stock look A688 unit
[Re: 70gtx440dana]
#2593272
12/17/18 05:59 PM
12/17/18 05:59 PM
NachoRT74
Valencia, España
And there was an intermediate model called HR688 which it was the aluminium box with an HEI module hidden inside.
