73'-74' Dodge Coronet/Charger CA bumper stops? #2588038
12/06/18 01:26 PM
12/06/18 01:26 PM
fullmetaljacket Offline OP
Is it me? or is it that the upper and lower control arm bottoming out bumper stops are hard to get?
Perhaps I'm looking in all the wrong places?
Doing my whole entire front end as we speak and these items are the only last things left to find.
Positive or negative results, Thank you in advance.
Re: 73'-74' Dodge Coronet/Charger CA bumper stops? [Re: fullmetaljacket] #2588040
12/06/18 01:37 PM
12/06/18 01:37 PM
3
340clone Offline
340clone  Offline
I recently bought a set of Dorman type at Autozone.
Dorman 531654 IIRC.
Also shows fit for Prothane 191303
Hope this helps.
Re: 73'-74' Dodge Coronet/Charger CA bumper stops? [Re: fullmetaljacket] #2588042
12/06/18 01:42 PM
12/06/18 01:42 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
www.cjmotorparts.com shows two of the NOS lower 3402776 The uppers should be the same ones they used on many mopars. 2535204 changed part number 4014050. If you don`t want NOS, I`m pretty sure the aftermarket ones for the lower arm don`t look the same in appearance if that matters but the uppers are pretty close.
Re: 73'-74' Dodge Coronet/Charger CA bumper stops? [Re: fullmetaljacket] #2598551
12/29/18 09:12 PM
12/29/18 09:12 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
Could have sworn I got factory style ones from Rockauto, that was a year ago though.
Re: 73'-74' Dodge Coronet/Charger CA bumper stops? [Re: Montclaire] #2598840
12/30/18 03:52 PM
12/30/18 03:52 PM
Yes, I just found them through a friend at a source that had original dorman types in stock.
Also found out that Jegs and Rock Auto has them as well.
Thank you.
Re: 73'-74' Dodge Coronet/Charger CA bumper stops? [Re: fullmetaljacket] #2598988
12/30/18 11:13 PM
12/30/18 11:13 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
I bought some upper ones for my 74 Charger at NAPA. Part number 265-4005.
Terry
