TF 727 no forward gears #2587148
12/04/18 06:57 PM
12/04/18 06:57 PM
ontario canada kingston
aspenrt360 Offline OP
Hey guy's, yep fresh rebuild by my regular guy never had any issues before with him. new 9.5 converter i had Lupo make a couple of years ago just got around to installing this week did the install like normal put my fluid in fired it up in neutral ran it through the shifter positions back to neutral topped it off enough to test it and i have reverse but nothing in 3 2 1 re checke fluid added a bit more just in case still nothing. stock floor shifter in an a body checked it a couple of time to be sure it was adjusted right kick down is on and set. any thoughts before i call my guy?
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: TF 727 no forward gears [Re: aspenrt360] #2587165
12/04/18 07:53 PM
12/04/18 07:53 PM
BLACKHEMIRR Offline
BLACKHEMIRR  Offline
Most likely a rear clutch issue or the rear clutch sealing rings. Unfortunately, there's probably a good chance the trans will have to come out again. Did the builder check the clutches with air during assembly?
Re: TF 727 no forward gears [Re: aspenrt360] #2587190
12/04/18 09:10 PM
12/04/18 09:10 PM
i have a feeling it could be something with the input shaft. the trans is a 78 from an e58 cop car no lockup and had a shift kit in it before, i ran it for years till it got a little soft then pulled it. upon inspection it needed an input shaft so i brought a core trans from my barn an he built it up from there. it seems to me there was change in that area around that time. i hope he did not miss that? but i will pull it to make sure. sucks but it is what it is.
Re: TF 727 no forward gears [Re: BLACKHEMIRR] #2587191
12/04/18 09:13 PM
12/04/18 09:13 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
x 2 .... probably blew out the rubber rings frown ... should have used some ATF with that air check
Re: TF 727 no forward gears [Re: aspenrt360] #2587198
12/04/18 09:28 PM
12/04/18 09:28 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A mismatch of the input shaft and/or the reaction shaft support is a distinct possibility, they changed the rear clutch apply circuit in '78.
Re: TF 727 no forward gears [Re: John_Kunkel] #2587202
12/04/18 09:38 PM
12/04/18 09:38 PM
after it did not work i read up on some possible causes and found that which made me think of what we did to it..... oh well i will pull it and we will see. i may just bring another one that i have and get it done too. this guy has built a lot of 727's for me with no issues so i can't complain too much stuff can happen. i will post back here once i know whats up i will try to get it pulled this week and get it to him before the weekend. i am trying to get this car done so i can store it for the winter as i need mu shop back!
Re: TF 727 no forward gears [Re: dOc !] #2587316
12/05/18 01:48 AM
12/05/18 01:48 AM
Doc edumacate me on that if you would please, I have several 904's in the works.
Re: TF 727 no forward gears [Re: RapidRobert] #2587327
12/05/18 02:05 AM
12/05/18 02:05 AM
Memphis,TN
J. Hammer Offline
J. Hammer  Offline
Memphis,TN
Be careful what you wish for.
Re: TF 727 no forward gears [Re: RapidRobert] #2587363
12/05/18 04:35 AM
12/05/18 04:35 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
EGGuCATE RR ? ... lol ..... now a 904 I totally furrget but a 727 has a BIG RUBBER Oring that can roll over if tooo high of air pressure is used OR if it isn’t changed on a rebuild and is worn out or brittle from heat. Now HONESTLY RR .. I have not seen the inside of a 727 (I had to think about this) since 1996 ..,, damn 22 years ! ...
Re: TF 727 no forward gears [Re: J. Hammer] #2587365
12/05/18 04:46 AM
12/05/18 04:46 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
Now HAMma’ time ... jsta what does THAT mean whistling.. penguin
Re: TF 727 no forward gears [Re: dOc !] #2587398
12/05/18 10:25 AM
12/05/18 10:25 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
No! We would have never guessed... rolleyes
'63 Dodge 330
11.19 @ 121 mph
Re: TF 727 no forward gears [Re: aspenrt360] #2587464
12/05/18 01:07 PM
12/05/18 01:07 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
Ahhhh ... my little PUPPY DOG is here pity
...and I’ll bet I’ve FORGOTTEN more about a 727 than you will ever know .,,. spank wave
Re: TF 727 no forward gears [Re: dOc !] #2587518
12/05/18 02:40 PM
12/05/18 02:40 PM
I'm sorry I asked!
Re: TF 727 no forward gears [Re: dOc !] #2587539
12/05/18 03:24 PM
12/05/18 03:24 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I don't know what you consider to be "tooo high" of air pressure, but I routinely use 90 psi for air checks theorizing that it's better to have a failure on the bench than in the car. And I add a squirt of ATF to the passage before air testing to ensure a better piston seal.
Re: TF 727 no forward gears [Re: aspenrt360] #2587540
12/05/18 03:26 PM
12/05/18 03:26 PM
Conroe , Texas
I
iapco103 Offline
iapco103  Offline
I
Conroe , Texas
one time I assembled the rear clutch wrong and put the piston spring upside down = no forward gears
Re: TF 727 no forward gears [Re: John_Kunkel] #2587551
12/05/18 03:41 PM
12/05/18 03:41 PM
John you're the man (as always!) & that is what I was wanting to be edumacated on as I had completely forgotten about doing the air checks & I for sure want to know that everything is good (as much as I can) while I am still on the bench.
Re: TF 727 no forward gears [Re: aspenrt360] #2587560
12/05/18 03:54 PM
12/05/18 03:54 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
RR ,.. that’s basically what I said except I didn’t mention specific psi. And I have had a NEW seal roll over on a air and atf port fill check once.
Re: TF 727 no forward gears [Re: dOc !] #2587568
12/05/18 04:00 PM
12/05/18 04:00 PM
Doc yes you edumacated me, I worded it wrong where it sounded like you did not contribute but you absolutely did. & Doc while I got ya on the line, I have this Motorhome here that needs a good home (it has your name on it!).
Re: TF 727 no forward gears [Re: aspenrt360] #2587583
12/05/18 04:10 PM
12/05/18 04:10 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
RR .... the WHOLE motor homey ? ... well FIRE that baby up and drive her down to the warm weather !!
Re: TF 727 no forward gears [Re: dOc !] #2587638
12/05/18 05:29 PM
12/05/18 05:29 PM
Doc don't tempt me.
