Re: I searched but not many conversations on 426SR heads from In
[Re: maxie]
#2586627
12/03/18 03:14 PM
12/03/18 03:14 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Haven’t had any in my shop, but they’re “supposed” to flow quite a bit more than the oe heads.
[Re: maxie]
#2586734
12/03/18 07:46 PM
12/03/18 07:46 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
What’s the thoughts on the 2.25 valve head. NOT the 2.400 valve head. My pistons are machined for the 2.25 valve size and the motor is 433 cid
Thanks Is this motor a 400 block with a 440 stroke, 3.750, crankshaft in it? Or is this a hemiroid motor?
[Re: maxie]
#2586961
12/04/18 11:08 AM
12/04/18 11:08 AM
Posts: 2,299 NE Ohio
DoubleD
NE Ohio
Are they a true direct bolt on or is there something needed to use them like a external oil line? They are a bolt-on no external lines - they were meant to be an upgraded Stock Replacement = SR. The HiPo version has the larger valve and adjusted valve angle - similar to the edelbrock Victor Jr. but with both the Hipo Head and the Edelbrock Victor jr. you need a bigger bore and a custom piston to take full advantage of the head design. As with anything form Indy having the valve job checked and making sure the valve springs are correct – along with a little clean-up of the ports will make a huge difference in the end result
[Re: maxie]
#2587799
12/05/18 10:34 PM
12/05/18 10:34 PM
Posts: 12,396 Taxes & Virus's R-US, NY
Dragula
I have the 2.4 heads, and they flow real good...Run those on my 605.
On a smaller 484 hemi we ran OOTB Eddy heads, and they ran low 10's on a very mild engine.
We like both heads....The nice thing about the eddy heads is the spark plug holes are already heli-coiled. I ended up doing that to my Hipo Indy canfield 2.400 heads.
