Re: Aftermarket power window kit [Re: varunner] #2628941
03/05/19 12:40 AM
03/05/19 12:40 AM
70duster340 Offline
70duster340  Offline
Skeptic, I believe you need to chill out. I missed that particular photo, so sue me. I'm using a cell phone for this currently, so things are pretty small. If you can't be cordial, don't bother answering any of my posts.
Re: Aftermarket power window kit [Re: varunner] #2628969
03/05/19 01:47 AM
03/05/19 01:47 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
He did answer your question so you should thank him not berate him for pointing out the obvious.
Re: Aftermarket power window kit [Re: stumpy] #2629133
03/05/19 01:38 PM
03/05/19 01:38 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
To add, the kits come with a variety of caps and adapters of different sizes so you can choose the smallest cap that fits. I have never seen it done but I have heard in some applications you can shim the window regulator back far enough that you can use OEM power window door panels without the hole. No, the original window cranks won't fit, however at one time they sold a deluxe version of this kit that came with an emergency window crank so you could pop off the door panel crank and manual wind the window up/down. I never had a malfunction with mine.
Re: Aftermarket power window kit [Re: 70duster340] #2629136
03/05/19 01:43 PM
03/05/19 01:43 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Contrary to what you may have been told, there are stupid questions.
You asked one.
Don't be the exception.
Re: Aftermarket power window kit [Re: Supercuda] #2629218
03/05/19 03:40 PM
03/05/19 03:40 PM
70duster340 Offline
70duster340  Offline
You asked one.
Because it may be someone's opinion that the question is "stupid", it doesn't warrant such a response, from either of you. Just because the answer may have been missed or obvious gives nobody reason to belittle another member.
This site used to be about helping other Mopar owners with information, parts, etc. I've been a member here for over 30 years now. I have been in the position to both receive and offer information and support whenever I thought I could. At no time did I do so in such a manner as some have here on this post. I sincerely hope that this won't be the norm moving forward.
Re: Aftermarket power window kit [Re: 70duster340] #2629380
03/05/19 09:22 PM
03/05/19 09:22 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
I posted NOTHING insulting or demeaning, I merely pointed out that you bumped a thread THREE times, without paying any attention to the contents. If you feel embarrassed, that's on you.
Re: Aftermarket power window kit [Re: Skeptic] #2629649
03/06/19 02:02 PM
03/06/19 02:02 PM
70duster340 Offline
70duster340  Offline
That's your opinion. I certainly don't need the attitude of someone who, for some reason, has a poor outlook on other members. Like you've never missed some detail sometime in your life. If you can't say it respectfully, don't bother to say it at all. When I get it, I am just going to fire back. I have no issue with that.
