Re: Quick Fuel carbs.: Any good?
[Re: 1970RT]
#2581082
11/21/18 02:44 PM
11/21/18 02:44 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I called them, they built my carbs for my 572 Hemi. I was satisfied. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: 1970RT]
#2581145
11/21/18 04:35 PM
11/21/18 04:35 PM
Posts: 17,840 S.E. Michigan
ZIPPY
S.E. Michigan
I got a Brawler during a sale (happy holley-days or similar) awhile back, it's pretty good. Basically same thing as a Proform. they probably have deals on them again this time of year.
I don't follow the whole business too closely anymore as I'm on the OEM side these days rather than performance...however If I understand correctly QFT bought Proform and this is their version of the proform carb.
among other basic tuning changes I had to drill and tap for transition slot restrictor jets. Good chance you will want to do the same, if you street drive very much. Like many other carbs marketed as "race" it was pretty rich going down the road, out of the box.
Brad H. helped me out on the whole deal and it came together pretty well. Not sure if it will run better or worse ETs than the previous carb but I enjoy driving it.
Rich H.
Esse Quam Videri
[Re: 1970RT]
#2581218
11/21/18 07:12 PM
11/21/18 07:12 PM
BradH
Just wanted to ask if anyone has had any experience with Quick Fuel carbs. and if they are a decent carb. or not. Specifically, the Brawler Die-Cast model. What is your application? Are you looking for a chokeless carb, or one like an upgrade from an OEM carb?
[Re: 1970RT]
#2581557
11/22/18 03:46 PM
11/22/18 03:46 PM
Posts: 30,994 Oregon
AndyF
Just wanted to ask if anyone has had any experience with Quick Fuel carbs. and if they are a decent carb. or not. Specifically, the Brawler Die-Cast model. The inexpensive carbs work fine as long as they are matched to the application. The more expensive carbs have more adjustments. If you need the adjustment capability then you need the more expensive carb. If you don't, then the less expensive carb will work just fine. Typically the camshaft is what makes or breaks the carb. The closer the cam is to stock then the cheaper the carb can be. You didn't provide any information on your combination so I have no idea if the Brawler carb will work for you or not.
[Re: 1970RT]
#2581620
11/22/18 06:08 PM
11/22/18 06:08 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
Out of the box the dominator I bought for the race car is not right. Goes way lean on the hit. Have not tried to fix it yet.
[Re: 1970RT]
#2581797
11/23/18 02:59 AM
11/23/18 02:59 AM
Posts: 304 Florida
Mark Whitener
Some need some tweaking on the calibration, but should be able to make any work with a little love. Price a billet Weekend Warrior from BLP if you are on a budget.
Mark Whitener [url=www.racingfuelsystems.com[/url]
