Re: SCAT superlight crank [Re: polyspheric] #2578964
11/15/18 11:08 PM
11/15/18 11:08 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
target bobweight?
I'm surprised no one has asked.
Re: SCAT superlight crank [Re: Jeremiah] #2579017
11/16/18 02:22 AM
11/16/18 02:22 AM
AndyF Offline OP
AndyF  Offline OP
Bobweight for the engine I'm building should be around 2300 grams. I don't have the pistons yet so I'm just guessing where they'll come in at. The Molnar rods are fairly light for a 7.100 long rod.
Re: SCAT superlight crank [Re: AndyF] #2580631
11/20/18 02:30 PM
11/20/18 02:30 PM
dogdays Offline
dogdays  Offline
Consider the shapes of the leading and trailing edges of the counterweights.
Experiments with shape run quite a while ago showed that the rounded leading edge and tapered trailing edge had the least amount of drag. So, I would say the crank manufacturer knew EXACTLY which direction the crank would turn.
R.
Re: SCAT superlight crank [Re: dogdays] #2580638
11/20/18 02:39 PM
11/20/18 02:39 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
R.
I bought a new K1 4.500 RB crank a few weeks ago, it has the same counterweight shape on the leading/trailing edges as described. This seems to be the conventional wisdom these days.
Rich H.
Esse Quam Videri
Re: SCAT superlight crank [Re: AndyF] #2580721
11/20/18 06:12 PM
11/20/18 06:12 PM
AndyF Offline OP
AndyF  Offline OP
I'm sure that the engineer at SCAT was going with a tear drop design on the counterweights. So a rounded nose and a v shaped tail. I talked to the engineer a few times when he was working on the CAD file for the superlight but I don't think we discussed the shape of the counterweights.
Re: SCAT superlight crank [Re: AndyF] #2580725
11/20/18 06:24 PM
11/20/18 06:24 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The bob weight of my 572 with Molnar 7.100"x 2.200" rods, Molnar 4.500' x 2.200" crank, Diamond 4.500" flat tops is 2238 grams
Doug
