Fan Belt question #2577940
11/13/18 03:01 PM
11/13/18 03:01 PM
Minnesota
W
Wiley Roadrunner Offline OP
W
Minnesota
I am looking to put a new fan belt on my 68 road runner, and would like it to look as OE as possible. I'm trying to find the correct part number for the fan belt for a 68 road runner with a 383 and no air conditioning or power steering. The two part numbers I keep coming across are 2806216 and 2843221. I think either would fit, but I would like to get the one that is most correct. Thanks in advance for your help and suggestions!!
Re: Fan Belt question [Re: Wiley Roadrunner] #2579258
11/16/18 06:24 PM
11/16/18 06:24 PM
BLACKHEMIRR Offline
BLACKHEMIRR  Offline
2532648 is the belt listed in my 1968 parts book. Application is 68 B-body, 383 and 440, w/o A/cond, engine to alt to fan.
It also says that 2843221 is for the HP 383 and 440 w/o A/cond for B & L (Dart and Barracuda), but lists it in the A, B, & C body car columns. A little confusing.
Re: Fan Belt question [Re: Wiley Roadrunner] #2579461
11/17/18 10:12 AM
11/17/18 10:12 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Don't put those repo belts on if you plan on driving it.
Re: Fan Belt question [Re: 71birdJ68] #2579536
11/17/18 01:26 PM
11/17/18 01:26 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
My experience with the Quanta Reproductions is similar but different.
Don't put those repro. belts on if you plan on Revving it!!!
They don't like RPM.
Ron
Re: Fan Belt question [Re: Wiley Roadrunner] #2579704
11/18/18 12:02 AM
11/18/18 12:02 AM
Greenwood Lake, NY
fuelishnsilly Offline
Greenwood Lake, NY
And yet Quanta claims they never have had an issue with them.
inherited a 69 roadrunner from my grand pop.
Re: Fan Belt question [Re: fuelishnsilly] #2579715
11/18/18 12:31 AM
11/18/18 12:31 AM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I've been told that with every failed item in the past 40 years!
Ron
Re: Fan Belt question [Re: Wiley Roadrunner] #2579731
11/18/18 01:36 AM
11/18/18 01:36 AM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
I went to my local tractor supply dealer near me and gave them the dimensions of the belts that I needed. They were able to provide me with belts that had the original appearance at a fraction of the cost. Granted, they don't have the Mopar part number but they look much closer in appearance than the cogged belts sold through the local auto parts stores.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
