Re: Mercedes technology
[Re: polyspheric]
#2578959
11/15/18 11:00 PM
11/15/18 11:00 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
I always dipped the pistons in oil to flood the rist pins, wiped off the excess and sprayed the rings with WD-40, then installed.
[Re: polyspheric]
#2579257
11/16/18 05:57 PM
11/16/18 05:57 PM
Posts: 10,020 Frostbitefalls MN (Rocky&Bullw...
gregsdart
If oil distribution is limited to pre-oiling there will be no oil above the oil ring. I lube everything lightly, so there is at least a film on every part like what would be there in a running engine, but will not drown the thing in oil. I can see where many,many,mnay years ago rings and things were crude enough it would be a good idea since they needed a fair amount of break in, but not with todays parts and machine work.
[Re: polyspheric]
#2579537
11/17/18 01:27 PM
11/17/18 01:27 PM
Posts: 1,213 Minn
SportF
Minn
So, Mercedes-Benz, builds thousands upon thousands of engines every year and puts a warranty on them. AND someone thinks the way they put engines together isn't a good idea?
[Re: polyspheric]
#2579567
11/17/18 02:30 PM
11/17/18 02:30 PM
Posts: 698 Alberta Canada
Edge
Alberta Canada
What does Mercedes know... hand built naturally aspirated 378 cu in engine 622 hp with a full Warranty spinning to 8000 RPM.
76 Duster
work in progress
