Page 2 of 4 1 2 3 4
Re: Hurst V Gate shifter fitment [Re: 383man] #2578270
11/14/18 05:58 AM
11/14/18 05:58 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Here is a picture of my Road Runners floor pan, and what is needed to fit a Jerico trans with LONG shifter. You will pretty much need to do the same to fit a Hurst V gate.
69 GTX 68 Road Runner
Re: Hurst V Gate shifter fitment [Re: MadMopars] #2578325
11/14/18 11:35 AM
11/14/18 11:35 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The Hurst "Ram Rod" and "Super Shifter" for a B body both use the same "L" bracket and longer rods. This requires cutting a slot about 2" wide in the back of the tunnel. No other cutting is required but I have seen some real hack jobs. Now you have to figure what to cover all that mechanism with. Back in the day, Hurst made these just for that purpose and provided a template to match the floor lines.
NOTE: the large hole in the floor as seen in the above post is not necessary with an a833 and these shifters. Also, the original hole in the top of the tunnel is still required. In 1974 these were $80. through a speed shop. I still have a couple and have tossed around reproducing them but haven't got around to it yet.
I should mention this is a '69 B body.
Re: Hurst V Gate shifter fitment [Re: Stanton] #2578361
11/14/18 12:51 PM
11/14/18 12:51 PM
Weatherford, Texas
RapidusMaximus Offline
Weatherford, Texas
I ran a Hurst V gate in my GTX for years, loved it, no more missed 3rd gear shifts. Now, with my GTX restored, including repairing the hole I cut in the floor pan and reinstalling the factory shifter and console, I remember why I changed to the V gate...jeez this factory shifter sucks, already tired of hitting my knuckles on the dash trying to grab 3rd drive laugh2
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: Hurst V Gate shifter fitment [Re: RapidusMaximus] #2578418
11/14/18 03:09 PM
11/14/18 03:09 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Then you need to do what I did, to my Dads Super Bee. I installed a new Comp Plus mechanism, and then made my own shift Rods with heim joints. It cuts the throw down by half.
Re: Hurst V Gate shifter fitment [Re: JERICOGTX] #2578419
11/14/18 03:11 PM
11/14/18 03:11 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Another view.
Re: Hurst V Gate shifter fitment [Re: JERICOGTX] #2578467
11/14/18 04:58 PM
11/14/18 04:58 PM
Weatherford, Texas
Weatherford, Texas
My brain is not grasping how that reduces the throw by 50%...the levers on the trans are still required to move the same amount fore and aft...is the difference in the shifter?
1968 Plymouth GTX
Re: Hurst V Gate shifter fitment [Re: MadMopars] #2578473
11/14/18 05:30 PM
11/14/18 05:30 PM
Washington
madscientist Offline
Washington
And how does all that clear the tunnel and all the crap in the way down there?
Re: Hurst V Gate shifter fitment [Re: RapidusMaximus] #2578496
11/14/18 06:37 PM
11/14/18 06:37 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Tolerance stack. When you see how much slop the stock style parts have, and the non positive stop, the shift lever multiplies that slop. Trust me, it's a night and day difference.
Everything fits the stock tunnel. No way I'd ever go back to stock stuff.
Re: Hurst V Gate shifter fitment [Re: JERICOGTX] #2578545
11/14/18 09:15 PM
11/14/18 09:15 PM
Weatherford, Texas
Weatherford, Texas
What are you using for a shift lever? Of course I'm using the stock lever that comes over and up towards the driver's thigh...lol...looks like this
1968 Plymouth GTX
Re: Hurst V Gate shifter fitment [Re: MadMopars] #2578574
11/14/18 10:24 PM
11/14/18 10:24 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Using the exact same shifter handle.
Re: Hurst V Gate shifter fitment [Re: MadMopars] #2578590
11/14/18 11:23 PM
11/14/18 11:23 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
50% is a lot of "tolerance stack" !!! I suspect the majority of that 50% is from longer levers on the shifter mechanism.
Re: Hurst V Gate shifter fitment [Re: JERICOGTX] #2578604
11/15/18 12:27 AM
11/15/18 12:27 AM
Washington
Washington
What size tubing is that? I may give that a shot if you got it in there without hacking stuff out.
The biggest PITA will be buying a left handed tap, and that's a phone call to MDS or whoever I buy that crap from.
Re: Hurst V Gate shifter fitment [Re: madscientist] #2578654
11/15/18 07:43 AM
11/15/18 07:43 AM
Weatherford, Texas
Weatherford, Texas
X2 if those tubes help that significantly I'd be down to build a set also.
1968 Plymouth GTX
Re: Hurst V Gate shifter fitment [Re: madscientist] #2578663
11/15/18 09:14 AM
11/15/18 09:14 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
[quote=madscientist
The biggest PITA will be buying a left handed tap, and that's a phone call to MDS or whoever I buy that crap from. [/quote]
1/2" tubing. I just used RH threads. Set it on the bench, and forget about it. IF I needed to make an adjustment, just loosen up one side of it, and turn it a turn or so, but it has been rock steady since being installed. I just bought heim joints on eBay, and went from there.
Re: Hurst V Gate shifter fitment [Re: JERICOGTX] #2578688
11/15/18 11:23 AM
11/15/18 11:23 AM
Washington
Washington
[quote=madscientist
1/2" tubing. I just used RH threads. Set it on the bench, and forget about it. IF I needed to make an adjustment, just loosen up one side of it, and turn it a turn or so, but it has been rock steady since being installed. I just bought heim joints on eBay, and went from there. [/quote]
Cool. So I'm ASSuming that you used 3/8x3/8 hiem joints??? I already have enough LH taps that I'll make mine LH/RH and call it good.
Re: Hurst V Gate shifter fitment [Re: MadMopars] #2578692
11/15/18 11:44 AM
11/15/18 11:44 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
That is correct.
Re: Hurst V Gate shifter fitment [Re: JERICOGTX] #2578863
11/15/18 05:32 PM
11/15/18 05:32 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
My 2 cents-
1) V gates are kind of cool in a Fonzi way however not necessary for full throttle, clutch assisted gear changes in a race prepped a-833. Pro-shift, face-plate, whatever.
2) The thing that is missing from the Hurst Comp plus is a reverse lockout. Like most other things these days all of the hardware/linkage is cheesy. If yours doesn't have them you need the for/aft limited bolts.
3) IF I was going to cut my mint factory 4-speed tunnel (I hacked the hell out out of mine) I'd be looking at a Long shifter instead of a Hurst. I never looked into them for a long time and it's literally night and day IMO. As Jeff said go with the turbing or at least 7/16" solid steel rod.
OR
IF I was going to leave the factory 4-speed hump I'd call Passon and see if he has any parts to convert a new comp plus shifter to a reverse lockout. He was able to hook me up with one a few years back.
4) IF you are going to nitrous and a manual trans I'd start a thread on it, there are many ways to skin that cat.
Re: Hurst V Gate shifter fitment [Re: MadMopars] #2578882
11/15/18 06:21 PM
11/15/18 06:21 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The Hurst "Super Shifter" is a an H pattern shifter with reverse lockout. Although mine is on the L bracket and has longer rods that requires cutting the tunnel I see no reason it can't be bolted to the trans like a stock shifter and use shorter rods.
Using all RH threads you're "lucky" if you get the adjustment bang on (but close is probably good enough). With LH and RH threads the adjustment is infinite whereas with only RH threads adjustment is limited to the width of a thread
Re: Hurst V Gate shifter fitment [Re: MadMopars] #2578885
11/15/18 06:23 PM
11/15/18 06:23 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
May as well use aluminum tubing while you're at it - or aluminum hex rod.
Re: Hurst V Gate shifter fitment [Re: Stanton] #2578963
11/15/18 10:07 PM
11/15/18 10:07 PM
Washington
Washington
The Super Shifter does not have a reverse lockout. The Super Shifter does have a reverse lockout.
Page 2 of 4 1 2 3 4
