i took them off my 69 b-body,never noticed a diff.my car is just a mid 10 sec street strip car, i dont really pull any Rockfords or twisty road driving.
RR, It will improve your handling, but your satisfaction will depend how sensitive you are to it. Yes, I think you will feel a difference. It would turn crisper, flatter, and create a little more understeer with a front sway. Add a rear sway and it'll go back to neutral and be much flatter in harder turns. Include stiffer shocks and your handling will be even one more step crisper. Larger, wider rims with better tires takes you another step... The more steps you take, the less comfortable it will be on the street.. Sways are a good first step.
How necessary it is, is up to you. Sways, shocks, rims, tires, are not expensive steps, easy to install, and each one improves your handling. At some point consider front discs to stop you better. But that's more money.
EXAMPLE: I like to track race, so I put a 9lb FirmFeel tubular sway on the front of our '65, plus a rear sway.. plus stiffer shocks.. plus stickier, wider tires but stayed with 14" rims (Ford 6.5") to absorb harshness.. I have a very reasonably soft ride with much tighter, flatter handling than before..
One of the first things I did to my Fifth Avenue was a set of matched cop car bars. Car originally only had a front 1 1/16" bar. The cop bars measure 1 1/8" and 0.75". It made a huge difference in regular street driving and changing lanes on the interstate. Honestly, it made it safer to drive.
If I was daily driving and old car I'd match a set of big sway bars and go soft on the torsion bars.
I bought a set of front and rears for my b-body. Before I got around to installing them, I put in a set of 1.05 T-bars. Holy Smokes, what a difference in handling with no change in ride quality! I'm not a roadracer, but the car takes the curves faster than I want to go, I never got around to mounting the sway bars.
I bought a nice, solid 67 383 fact a/c 2 door satellite years ago, and that thing leaned quite a bit on any decent corner. Got a stock 67 gtx sway bar from a friend, added tabs to lower arms, and put urethane bushings on end links too. It helped that nose heavy cruiser.
And thanks again for your help in several question!
Hey you are welcome. Sitting in front of the computer motionless is my favorite activity! On the S/B, there is one for sale for $80 WO the links etc. Just wondering if I should jump on it or not as the complete kit is ~2 bills & I'm sure the extras needed are available seperately.
I have a BB A-body so it's a tick nose heavy. Added frame connectors and a front and rear sway bar set from Hellwig. I think the car handles quite well for a street cruiser. Lots of fun out on the rural roads.
I bought a 67 Mustang that had the suspension modified with sway bars and lowering springs by the previous owner. That thing cornered dead flat. Spooked a couple passengers by not slowing down for a corner or two like they expected an old car would have to do.
Big bars and moderate springs will give a better ride and still corner well.
Early A body. daily driver. easy driven around town. would it show much difference in turns/be worth the investment? thank you for your time.
Huge difference between no bar and a peformance bar. There is also a big difference between factory torsion bars and larger bars as well as factory tires and modern tires. All depends on where you want to stop.
I rode in a fairly stock GTX the other day and was surprised at how mushy it was. Been a long time since I was in a stock suspension Mopar so I'd forgotten how soft they are.
The one I got in mind is an Addco #751 & it is 1&1/8". 63 dart convertible I am resurrecting next year. EDIT I remember seeing an early A OE front sway bar & it is very small. (that jogged a memory from the /6 club of America literature decades ago, maybe 7/8"). I will have top notch tires on it.
My 69 Satelite weighs in at 3860. I have SS springs on the back and 1.05 torsion bars on the front and KYB shocks. Also helping are 17" wheels and z rated tires. No sway bars. I am not trying to speak against sway bars, as long as you are not a commited drag racer, there is no down side other than expense. The point I am getting to, is that handling is an integrated system. If you springs/torsion bars are worn out, no sway bar is going to band-aid that. 40 year old tire designs, parts store shocks(not that KYB's are that much better) all lead to excessive body lean and poor handling. Like I said earlier, just switching to new bigger bars made a world of difference. I talk to Mopar guy's all the time and am amazed that better than 50% of them are still running 45 year old torsion bars, most of them were too small to begin with and now they are worn out. I talked several of my B body friends into new bigger bars and they loved the increase in handling with no downside in ride quality. Sub-frame connectors are a big plus also.
If I had to choose between thicker torsion bars or adding a sway bar, I would go for the torsion bars. That being said, I think the sway bars are great in a nose heavy car to help counter body roll in the turns. With something lighter I wouldn't be as concerned.
That is a real good point on the tbars. Actually I will be doing 2 of em, One a BB (& not sure how much aluminum will be on the eng) & the other a SB daily driver. I kinda wanted to nab the sway bar for $80 before somebody else does. Here's one & I ain't got another one yet.
Significant improvement, probably the best 'handling improvement' out of any suspension modification other than subframe connectors and a modern radial tire. My 69' Road Runner handles like a modern car, with the Hotchkis suspension & properly tuned Fox shocks. Hotchkis tuned all their components on track cars, torsion bar suspension works when it's designed properly.
I've previously owned a Corvette Z06, SRT 392 Challenger, and Saleen Mustang as a reference.
1969 Plymouth Road Runner (440 w/ Boost! RIP) now a low-deck 470 with hotchkis suspension, nascar boom tube exhaust, & big brakes.
1. Reduces body roll, which from a drivers perspective, often improves driver feel and confidence 2. Reducing roll can improve tire patch orientation IF it is excessive and/or not favorable to begin with, when cornering hard 3. It reduces total tire grip on that axle relative, to the improvement maybe gained in #2 above, by placing more load on one tire, and reducing tire loading on the other, which ALWAYS reduces that axles total grip. A swaybar never "equalizes" tire loading, quite the opposite, contrary to what many think.
#3 can be beneficial in that it might "balance" the two axles for improved driver "feel", but it is accomplished at the cost of tire grip.
Adding a rear bar is one way of reducing the effectiveness of an oversized the front bar.
Plan on doing some fabbing with Addco bars.
I think a front sway bar is almost always worth it. With the small early a-body, and no other changes, a factory bar or the smallest aftermarket bar will be a decent match.
JCC's summary is absolutely correct and the third point worth keeping in mind whenever faced with a pitch to make the suspension more rigid.
If I was faced with the choice of using big torsion bars with KYB shocks OR a stock torsion bar, GOOD shocks and moderate sway bars, I'd take the second option every time. KYB shocks are like a kick to the crotch. I'll never run them on any car that I am keeping.
3. It reduces total tire grip on that axle ... by placing more load on one tire, and reducing tire loading on the other, which ALWAYS reduces that axles total grip...
This explains why a front sway will increase understeer, and a rear sway will increase oversteer: Whichever end has a sway will tend to break away before the end without a sway.
There's probably a lot more on this in the "Corners Are Best" forum. - Art
You don’t have to plan on building a toad racer to use a sway bar, they make a great improvement on a cruiser. I would see if helwig has something for your car, they make a great tube bar. Much better brackets, fit and finish, than addco for the 67+ a bodies.
I have an ADDCO early A sway bar on my 65 Cuda. You are better off without the brackets, pretty lame and you'd end up making your own. The Hellwig is much better.
on my 74 Duste360, I upgraded the t-bars with 1.06" and left the factory front sway bar - added urethane bushings to it ! Then added ADDCO 3/4" rear sway bar, used KYB Gas-A-Just shocks on all corners . . . car handled great, and I really did not see or feel change in ride - put over 100k miles on that combination . . .
Good place IMO to insert a quote from one of the most enlightening books of dozens I have read on performance solutions mindset, "Think Fast" by Neil Roberts,
