Re: Bleeding Strange front Disc Brakes
[Re: Sammy]
#2576311
11/09/18 01:17 PM
11/09/18 01:17 PM
Posts: 7,477 Minnesota
Hemi_Joel
Minnesota
It's good practice to bleed all four calipers whenever the system has been opened up. You only need to bleed the top screw on each side of the caliper. Start with the right rear outer, then the right rear inner, then the left rear outer, then the left rear inner, then the right front outer, then the right front inner, then the left front outer, then the left front inner.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Sammy]
#2576314
11/09/18 01:19 PM
11/09/18 01:19 PM
Posts: 20,158 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Sammy you may not end up doing it but I ended up buying a pressure bleeder from Summit to get my Strange brakes bleed right. Man that thing worked great.
[Re: pittsburghracer]
#2576342
11/09/18 02:14 PM
11/09/18 02:14 PM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Sammy you may not end up doing it but I ended up buying a pressure bleeder from Summit to get my Strange brakes bleed right. Man that thing worked great. Got a link to that pressure bleeder. Why us it better than gravity bleeding?
[Re: Hemi_Joel]
#2576345
11/09/18 02:16 PM
11/09/18 02:16 PM
Sammy
Wind Gap,Pa.
It's good practice to bleed all four calipers whenever the system has been opened up. You only need to bleed the top screw on each side of the caliper. Start with the right rear outer, then the right rear inner, then the left rear outer, then the left rear inner, then the right front outer, then the right front inner, then the left front outer, then the left front inner. Thanks even though I never touched the rear system?
[Re: Sammy]
#2576348
11/09/18 02:22 PM
11/09/18 02:22 PM
Posts: 20,158 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Sammy you may not end up doing it but I ended up buying a pressure bleeder from Summit to get my Strange brakes bleed right. Man that thing worked great. Got a link to that pressure bleeder. Why us it better than gravity bleeding? Don't ask me but I tried everything even thinking it must be the master cylinder so I bought and installed a new one. I bought the motive kit. You can call and buy the kit for your set-up or buy the universal one so you are set up for all your cars. https://www.summitracing.com/search/depa...and-accessories
[Re: Sammy]
#2576435
11/09/18 04:47 PM
11/09/18 04:47 PM
Posts: 11,526 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Only use the bleed screws at the top. Calipers with screws on both sides and done like that so they can be mounted either direction. Rears should only need to be bled if they got air in them at the master, but if they've been together for a while, I'd bleed and flush them while I was there.
[Re: CMcAllister]
#2576456
11/09/18 05:30 PM
11/09/18 05:30 PM
Sammy
Wind Gap,Pa.
Only use the bleed screws at the top. Calipers with screws on both sides and done like that so they can be mounted either direction. Rears should only need to be bled if they got air in them at the master, but if they've been together for a while, I'd bleed and flush them while I was there. They are new in the box. I pumped them up to try and get a pedal, from only the outer top first then bottom on the outside bleeders. Opened up the reservoir cap and bubbles were flying around in there.
[Re: Sammy]
#2576476
11/09/18 05:58 PM
11/09/18 05:58 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Air rises to the top. Bleed from the both tops only. Don't pump it. You just aerate the fluid and make it impossible to bleed until you leave it set awhile.
[Re: Sammy]
#2576526
11/09/18 07:57 PM
11/09/18 07:57 PM
Posts: 20,158 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Sammy you may not end up doing it but I ended up buying a pressure bleeder from Summit to get my Strange brakes bleed right. Man that thing worked great. Got a link to that pressure bleeder. Why us it better than gravity bleeding? Don't ask me but I tried everything even thinking it must be the master cylinder so I bought and installed a new one. I bought the motive kit. You can call and buy the kit for your set-up or buy the universal one so you are set up for all your cars. https://www.summitracing.com/search/depa...and-accessories Hey, will this one work for the dual mopar master cylinder? I can live with this price tag. https://www.summitracing.com/parts/mvp-0103/applications/?ibanner=SREPD2 Your best bet would be to call them and tell them what master cylinder you have.
