Page 2 of 9 1 2 3 4 5 6 7 8 9
Re: Garage Project [Re: skicker] #2164911
09/30/16 02:47 AM
09/30/16 02:47 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
very impressive
Re: Garage Project [Re: skicker] #2174514
10/14/16 01:27 PM
10/14/16 01:27 PM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
I have added the temporary shoring under the metal pan decking at the basement.
...FAFO...
Re: Garage Project [Re: skicker] #2174519
10/14/16 01:35 PM
10/14/16 01:35 PM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
Wood was installed around the steel beams to prevent concrete from the upper slab pour from reaching the basement.
Several penetrations were made through the metal decking into the dividing wall above for electric and for return of air lines and such.
I still need to do a couple more near the panel for the floor heating to return low voltage thermostat wires.
Concrete pour of the slab is scheduled for Monday 10/17/16.
...FAFO...
Re: Garage Project [Re: skicker] #2174522
10/14/16 01:42 PM
10/14/16 01:42 PM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
I also managed to get the fittings installed on the pex tubing and pressurized the system to 50 pounds.
I need to install a few more braces on the pour stop at the doors...clean up some leaves and maybe do a little caulking to prevent concrete from getting to the basement and it should be ready to pour.
Extended weather for Monday looks like partly cloudy and 77 degrees...80 for Tuesday with no rain shown till Thursday... luck
...FAFO...
Re: Garage Project [Re: skicker] #2176471
10/16/16 10:47 PM
10/16/16 10:47 PM
WV
Little Detroit Online content
Little Detroit  Online Content
WV
don't forgfet to put a thermal barrier exactly under the garage doors where they should seal to floor,we 3 2x6's then the apron is poured against the thermal barrier ,keeps cold weather from penetrating to your heated floor.
Re: Garage Project [Re: skicker] #2179439
10/20/16 10:38 PM
10/20/16 10:38 PM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
Concrete pour went off without any problems...
We used particle board to lay down over the pex tubing to wheel the concrete to the back corners.
Pex tubing stayed pressurized at 50#'s throughout.
Little Detroit there was no way to do the thermal break as you suggested. Had I stopped the slab under the center line of the garage doors it would have been easier...however the existing rebar and wire mesh stopped at the exterior of the 12" block.
I'll come back in the spring and install the aprons to transition from the gravel to the new floor. I'm thinking maybe 3' long with about 1/2" of slope away...
...FAFO...
Re: Garage Project [Re: skicker] #2179444
10/20/16 10:48 PM
10/20/16 10:48 PM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
I ordered the concrete with fiber in it.
Typically you use wire mesh or fiber to prevent cracking...I opted for both...22 Yards of concrete later it is finished. boogie
The concrete was finished Monday afternoon.
It has set long enough now that I can remove the pour-stop at the garage doors maybe tomorrow weather permitting.
I've been trying to come up with a plan for sealing or painting the floor.
The right half (about 22') will be storage only and I would like to do something nice on the floor. The other half will be a working bay and will get welded and painted on so I'm up in the air as to what to do with it... shruggy
...FAFO...
Re: Garage Project [Re: skicker] #2180309
10/22/16 01:40 PM
10/22/16 01:40 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Re: Garage Project [Re: skicker] #2180741
10/23/16 10:13 AM
10/23/16 10:13 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
Damn...now THAT's a project! Thanks for posting the pics. Will the floor support a 4 door Imperial?? apimp grin
I'll soon have a garage/pole barn (56 x 40'...heated floor) put up on some ground that once was 4-5' high on one side. Had considered partial concrete walls, but decided on flattening the ground. Will end up with 2 or 3' retaining wall 10 ft from the building, and slope the ground behind the retaining wall.
Re: Garage Project [Re: jughed] #2181152
10/23/16 11:43 PM
10/23/16 11:43 PM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
It will hold an Imp...or two...Since I have a dually I made sure of it...
I know not having flat ground is a pita...I spent a lot of years with cars stored at garages other than at home...paying rent and driving a half hour or twenty minutes away to work on them...No more... boogie
RS23...that is a nice ride for sure...Its just not a 65 B Body... shruggy
The winter months will consist of busting my tail to pay for everything as much as possible so I can start the wall framing in the spring...
Somewhere between now and then I need to have a few conversations with Stu regarding the garage doors... wave
Once the temporary shoring is removed I may put some heat in there over the w/e's this winter and work down in the basement.
One good sign was we did get a little rain late this week and all the water runs to the floor drains... up
...FAFO...
Re: Garage Project [Re: skicker] #2181383
10/24/16 01:18 PM
10/24/16 01:18 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Re: Garage Project [Re: skicker] #2191010
11/06/16 10:40 PM
11/06/16 10:40 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
So is this going to be one of those stories where we find survivor cars buried underground.lol
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Garage Project [Re: 67mprfan] #2191060
11/06/16 11:33 PM
11/06/16 11:33 PM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
No worries there...Most of my stuff is junk...But this will eventually let me get back to work on the 65 Bel II... up
You know...the one I started before I started to build the 70 Satellite??? Before the 69 "Banshee" Dart...before the 65 Coronet AWB and now the 72 Duster... nervous
These cars are a sickness... realcrazy
...FAFO...
Re: Garage Project [Re: skicker] #2202610
11/25/16 10:00 PM
11/25/16 10:00 PM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
Managed to get all of the wood cap on the top course of block for the garage... up
Installed the foam backer underneath so everything should be watertight for winter... boogie
Then went down to the basement and removed all the temporary shoring from under the elevated slab...
I still need to remove the 4x6 wooden beams but I'll wait till I can get help one day...
Went and picked up the 2 windows for the ends today...maybe I can get those in tomorrow... shruggy
...FAFO...
Re: Garage Project [Re: skicker] #2202885
11/26/16 04:33 PM
11/26/16 04:33 PM
Boca Raton, Florida
jpilone Offline
jpilone  Offline
Boca Raton, Florida
I am totally jealous! We can't do these kind of things down here where I live, not without having super expensive properties with plenty of land, or going further north miles away from anything.
-Jarrod Pilone
'70 Plymouth RR Convertible with amazing custom paint(Tribute/Recreation/Whateveryouwannacallit)
My Project Thread
Re: Garage Project [Re: skicker] #2204556
11/29/16 05:03 PM
11/29/16 05:03 PM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
Here's the pic with all of the wood cap on the block. This is how it will sit until spring when I build the rest.
Trick now will be to keep the leaves and crap off of it as not to stain the floor all up... rant
In the meantime I can still research efficient garage and entry doors and windows... up
...FAFO...
Re: Garage Project [Re: skicker] #2204876
11/30/16 12:30 AM
11/30/16 12:30 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Looking very nice!
Re: Garage Project [Re: skicker] #2206121
12/01/16 10:46 PM
12/01/16 10:46 PM
Southern by Choice
Shoozy Offline
I have a foot fetish
Shoozy  Offline
Southern by Choice
Great progress Lisa. Seriously well-engineered up
Old, tired, and sometimes broke down. Me, not my car...
Re: Garage Project [Re: Shoozy] #2206135
12/01/16 11:00 PM
12/01/16 11:00 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Re: Garage Project [Re: Shoozy] #2206377
12/02/16 10:59 AM
12/02/16 10:59 AM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
Damn deplorables... whistling
...FAFO...
