Just got the revenator, have a question #2575118
11/06/18 11:45 PM
11/06/18 11:45 PM
PA
Moparpete Offline OP
PA
there closed now so that's the reason for the post.got the revenator and the coil package, question is about the 2 pin ballast that came with the ECU. The car this is going g into is a 83 and it had the 4 pin type, do I have to use the 2 pin or is the 4 pin good enough for the revenator?
Re: Just got the revenator, have a question [Re: Moparpete] #2575131
11/07/18 12:20 AM
11/07/18 12:20 AM
Badham Co.
Y
Y3 70 BEE Offline
Y3 70 BEE  Offline
Y
Badham Co.
Wells 4 pin GM module gets it done
Re: Just got the revenator, have a question [Re: Moparpete] #2575135
11/07/18 12:31 AM
11/07/18 12:31 AM
Badham Co.
Y
Y3 70 BEE Offline
Y3 70 BEE  Offline
Y
Badham Co.
What is really in The REV N NATOR?
Re: Just got the revenator, have a question [Re: Moparpete] #2575144
11/07/18 12:57 AM
11/07/18 12:57 AM
PA
PA
thanks for the bump, but please if you have nothing constructive to add to the question at hand just move it along skip
Re: Just got the revenator, have a question [Re: Moparpete] #2575159
11/07/18 01:51 AM
11/07/18 01:51 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
You are not a moderator so unless one steps in, it is a FREE country.
Don't like it? Start your own forum and enforce whatever rules you want.
"What is really in The REV N NATOR?"
Digital circuitry....It works more efficiently compared to the factory style spark boxes.
I had a Rev-N-Nator. It worked fine but it OF COURSE did not provide 40 HP gains as stated in some tests. I didn't like that it was not compatible with vacuum advance so I sold it.
Re: Just got the revenator, have a question [Re: Moparpete] #2575182
11/07/18 03:19 AM
11/07/18 03:19 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
If the revenator is a 4 pin module then you only need the 2 pin (terminal) ballast. You could use the 4 pin and the 5 ohm side will be dead but I don't know if the primary coil side of your 4 pin ballast is the same ohm as the 2 pin ballast that's comes with your revenator. You can ohm it and check or just use the 2 pin ballast that came with the revenator which is what I would do. Good luck , Ron
Re: Just got the revenator, have a question [Re: Moparpete] #2575183
11/07/18 03:22 AM
11/07/18 03:22 AM
WA
tman Offline
tman  Offline
WA
Just hook it up. Don't worry about the 2 pin.
Re: Just got the revenator, have a question [Re: Moparpete] #2575211
11/07/18 09:35 AM
11/07/18 09:35 AM
SINY
SanityLost Offline
SanityLost  Offline
SINY
WELCOME TO MOPARTS
Re: Just got the revenator, have a question [Re: Moparpete] #2575224
11/07/18 10:58 AM
11/07/18 10:58 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Ahhh. Moparts. Kind of like watching congress on C span!
Re: Just got the revenator, have a question [Re: Moparpete] #2575260
11/07/18 12:24 PM
11/07/18 12:24 PM
I'm assuming the revn pkg comes with a coil included so yes you would use the 2 pin that is in the kit as this "sets" the voltage that the coil will "see" when running & this is the voltage amt that the revn ECU will make/break to trigger the coil. A full 12V coil setup would not use the ballast. I hear the revn is dependable but X2 on the HP hype! On a side note: on a "regular" ECU conversion from points or OE ECU you would mix/match ballasts to get the ohms ideal for the coil you are useing & you can parallel wire 4 terminal ballasts to get the ohms down. A 5 pin OE ECU (like what your car started with) would require the 4 terminal ballast that was originally in there but definitely not used for your conversion/question. When up & running holler if the revn is good.
Re: Just got the revenator, have a question [Re: RapidRobert] #2575265
11/07/18 12:28 PM
11/07/18 12:28 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Pete not sure what they give you but they said my stock 4 pin was fine when I did mine. I remember measuring the ohms at the time and it was OK.
Ron
Re: Just got the revenator, have a question [Re: Moparpete] #2575286
11/07/18 01:03 PM
11/07/18 01:03 PM
PA
PA
got it for the 73 RR, thank Ron for the straight up answer
Re: Just got the revenator, have a question [Re: Kern Dog] #2575298
11/07/18 01:33 PM
11/07/18 01:33 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i'm curious; do the rev-n-nator folks say the box won't work with a vacuum advance?
Re: Just got the revenator, have a question [Re: Moparpete] #2575320
11/07/18 02:12 PM
11/07/18 02:12 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I try, if I don't know I'll tell you that too. I think it's a very nice piece of equipment, I think I told you in another post I dummy'd it up with stickers.
Ron
Re: Just got the revenator, have a question [Re: lewtot184] #2575339
11/07/18 02:53 PM
11/07/18 02:53 PM
dogdays Offline
dogdays  Offline
Well, I read the patent for the Rev-N-Nator. #8584651 B1
It is some pretty impressive work. It also shows that some of my earlier thinking was incorrect.
For example, the TO-3 case on top of the box is not a transistor, it's a voltage regulator made to look like the Mopar transistor.
The box keeps a running average of the time between sparks and fires when it calculates the next spark should occur. A microprocessor does all the thinking. The inventor calls it a "digital flywheel".
A coil driver supplies voltage to the coil.
I was surprised about a year ago to see an article online explaining why certain high performance engines use optical triggering rather than magnetic, and the reason they gave was spark-to-spark variability. There are several degrees of variation in the spark, between cylinders.
This was in a racing type distributor without vacuum advance. Adding vacuum advance adds another source of jitter which makes the Rev-N-Nator's microprocessor's job all the harder.
They do say in the FAQ that in certain circumstances vacuum advance is OK.
Most of us know that at part throttle, the engine can tolerate more spark advance. By adding advance at part throttle, the vacuum advance can increase economy. I could see a future example of the box using a MAP sensor to alter the timing curve to achieve the same function. I know that some digital controls do that already, along with most automobiles built in the last 20 years.
R.
Re: Just got the revenator, have a question [Re: Moparpete] #2575403
11/07/18 04:12 PM
11/07/18 04:12 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have had one on my 70' Charger now for many years & 10's of thousands of mile and hundreds of passes with no issues. No real horsepower/torque increase felt as claimed but I just like it for the built in rev limiter. My car is an automatic so it's not like I over rev it too often anyway. Just having it there makes me feel a little better just in case.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Just got the revenator, have a question [Re: Moparpete] #2575476
11/07/18 07:02 PM
11/07/18 07:02 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
I know from experience that using a vacuum advance with an aggressive centrifugal curve can be tricky, but don't see where the actual timing in degrees advance would have any effect on the electronics. the thing just fires either sooner or later in the power curve. I do look at dwell with any of the boxes and do notice differences between them. not sure how relevant that is in creating spark energy.
Re: Just got the revenator, have a question [Re: Moparpete] #2575520
11/07/18 08:30 PM
11/07/18 08:30 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
The vacuum advance issue not wanting to work with the revinator most likely would be caused by the reluctor not in phase with the cap. There is not one valid reason for any ignition box not to like proper timing advance and the engine appreciates it the most. These are not 10 sec dragsters
When the rotor is out of phase it gets confused as to where to send the spark esp when the plate advances ...amazing isn't it? Simple too.
Most distributors require phasing.
Now play nice children or you can figure this out yourselves.
