Re: Brakes are very sensitive, Booster?
[Re: Moparpete]
#2574541
11/05/18 07:22 PM
11/05/18 07:22 PM
Posts: 18,157 Mass
DAYCLONA
Mass
1973 plymouth RR. car runs and drives great now but the brakes are very sensitive with little to no pressure on the pedal the front brakes will lock up would a booster that is going bad cause this? Car has sat for sometime before I started working on it for the original owner , nothing is leaking by the wheels ie calipers or wheel cylinders. Have you made any changes/repairs to the brake system? were any changes made to the brake system when it was parked?, is/was this a prior problem?...just like to ask before the "ghost" chasing starts
[Re: Moparpete]
#2574632
11/05/18 10:30 PM
11/05/18 10:30 PM
Posts: 531 Charlotte, NC
Kowal
Charlotte, NC
Does it get better as it drives?
I had a bad brake line proportioning valve that kept hanging up. Made brakes very touchy early on a each drive, settled as it must have loosened up with maybe engine compartment heat. Anyway, changing it fixed it.
'69 Hemi Charger 500, ‘70 U code Challenger R/T (These and a bunch others at www.dkowal426.com) P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
[Re: Moparpete]
#2574789
11/06/18 12:34 PM
11/06/18 12:34 PM
RapidRobert
Offhand I would think it is a booster/check valve issue
[Re: 469runner]
#2575639
11/08/18 12:12 AM
11/08/18 12:12 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
What you describe is a symptom of a bad reaction valve in the Booster. I bought a new power brake booster for a truck a few years ago through mail order. Same symptoms, just the slightest pressure on the pedal and BANG, everything in the truck headed for the windshield. Took the booster to a local brake shop. He dropped small disc in the center hole, maybe it was a reaction disc, I don't know. Anyways the problem was resolved.
[Re: Moparpete]
#2575794
11/08/18 11:44 AM
11/08/18 11:44 AM
Kowal
Charlotte, NC
actually thought it did improve a little after backing up with the car and pumping the brakes as i backed up but after another regular drive it was acting the same If it is the proportioning valve is there any kind of rebuild for it or just remove and send cleaners through it along with compressed air Regarding the valve. I never tried rebuilding them, just bought new and swapped out. There’s a couple of good sources...The Ram Man is helpful and will send you one that he tested first, In-line Tube sells them and I have had good experiences with them (but you have to know what you want in terms of the exact piece) and then there is Right Stuff Detailing (their website can be a little confusing in that products appear and disappear depending on which menu you use to enter an area). All three sell on e-bay, but I would research first. Or just call The Ram Man and talk to him, he can be a little crazy when it comes to brakes but he is a very good guy, knows a ton and has helped me a couple of times with various cars. Look up The Ram Man Inc online and it has his phone number.
[Re: Moparpete]
#2575795
11/08/18 11:47 AM
11/08/18 11:47 AM
Kowal
Charlotte, NC
Regarding the Ram Man. Ask to talk to Wayne directly. Tell him what it is doing and see what he says. As I mentioned above, I have worked with him several times, we discussed what I needed and that is exactly what I got. Good Luck
[Re: RJS]
#2576280
11/09/18 12:33 PM
11/09/18 12:33 PM
Posts: 206 PA
Moparpete
PA
Pete what does the brake fluid in this car look like?? If it was sitting a good bleeding may be enough to get the moisture out and free up the proportion valve. Also try a replacement check valve on the front of the booster. Ron not real sure on the fluid car was sitting for a long time with the owner only driving very little the last few years the car is officially sold now the new owner has said that he is more than capable of doing whatever repairs are needed on the car, so the original owner has agreed to let the car go to the new owner with what ever items need attention. Wishing the new owner lots of luck with the car, it's a rare piece even though it's a 73 RR it does need tlc and after getting to know the new owner a little bit more it really sounds like the car is going to be in some really good hands now. Thanks to all who have replied.
[Re: Moparpete]
#2576568
11/09/18 10:36 PM
11/09/18 10:36 PM
Posts: 6,224 JERSEY
RJS
JERSEY
Pete what does the brake fluid in this car look like?? If it was sitting a good bleeding may be enough to get the moisture out and free up the proportion valve. Also try a replacement check valve on the front of the booster. Ron not real sure on the fluid car was sitting for a long time with the owner only driving very little the last few years the car is officially sold now the new owner has said that he is more than capable of doing whatever repairs are needed on the car, so the original owner has agreed to let the car go to the new owner with what ever items need attention. Wishing the new owner lots of luck with the car, it's a rare piece even though it's a 73 RR it does need tlc and after getting to know the new owner a little bit more it really sounds like the car is going to be in some really good hands now. Thanks to all who have replied. OK cool, now are we allowed to see it??? Ron
