Shaker base plate #2574373
11/05/18 01:35 PM
11/05/18 01:35 PM
71ragtop Offline OP
71ragtop  Offline OP
How can you tell the differance between a 340,383 and 440 E-body shaker base plate? Thanks.
Re: Shaker base plate [Re: 71ragtop] #2574393
11/05/18 02:17 PM
11/05/18 02:17 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
340 has 2 tabs on front, facing forward to bolt straps to head, 383 has a single hole in middle that bolts to intake gasket center rail bolt. 440-6 has 2 tabs facing out towards inner fenders for tabs that rest on valve cover. Do a search, was just a great topic on here with pics and all measurements,
Re: Shaker base plate [Re: 71ragtop] #2574552
11/05/18 07:46 PM
11/05/18 07:46 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: Shaker base plate [Re: 71ragtop] #2574767
11/06/18 11:46 AM
11/06/18 11:46 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I restored a car with a 383 baseplate on a 440 engine. They had dropped the k frame with 3/4” blocks to make the hood shut! Had to buy a repop 440 plate. Still have the oem 383 if that’s what you need.
Re: Shaker base plate [Re: DAYCLONA] #2575053
11/06/18 09:50 PM
11/06/18 09:50 PM
71ragtop Offline OP
71ragtop  Offline OP
Thanks for all the information,it really helped!
