LBS Braking System Question? #2571845
10/30/18 10:30 PM
10/30/18 10:30 PM
moparAL Offline OP
moparAL  Offline OP
Several months ago on a post on Moparts, a member mentioned a product, a add-on device added to a braking system called (LBS) lock resistant brake system. Most of the post talked about add on $$$Anti Lock systems. But the LBS portion I found interesting. Has anyone ever used this system and with what kind of results? Any thoughts?
http://www.73-87.com/7387garage/chassis_suspension/lbs.htm
http://www.larsenracingproducts.com/products/lock-resistant-brake-system-lbs.html
Re: LBS Braking System Question? [Re: moparAL] #2572218
10/31/18 04:02 PM
10/31/18 04:02 PM
Colorado front range
BcudaChris Offline
BcudaChris  Offline
Curious on this one. I've pondered the Ehrenberg setup to get RWABS (basically poaching a control box, etc. from an older Dakota, and drilling the pumpkin for a pickup and tacking a tone ring on to the carrier.
This seems betterfastercheaper.
Re: LBS Braking System Question? [Re: moparAL] #2572425
10/31/18 11:43 PM
10/31/18 11:43 PM
moparAL Offline OP
moparAL  Offline OP
I guess I interested in a poor mans, simpler, ABS like parts.
Re: LBS Braking System Question? [Re: moparAL] #2572453
11/01/18 12:28 AM
11/01/18 12:28 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
The Larsen product isn't ABS, neither is the old RABS system. The RABS system was only to keep unloaded trucks from swapping ends and didn't work very well beyond that. You could, and would lock the front brakes during hard stops. There was an "anti-skid" device being marketed that was mounted inline @ the master cylinder some years ago. It made all sorts of claims about damping pressure surges and reducing stopping distances. It. Failed. All. Tests. and was taken (forced) off the market. Effective anti-lock systems are costly and complicated, and respond to changes in traction 20X per second at each corner independently. a non-feedback system can't respond to the changes in traction. Slowing down the application of the rear brakes when it isn't needed for lock up control is going to add additional load on the front brakes. It may give some benefit to a race car, but I'd need to see independent testing for proof. So if you are so inclined, spend the coin and do some before and after testing.
Re: LBS Braking System Question? [Re: moparAL] #2572787
11/01/18 10:23 PM
11/01/18 10:23 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
RWAL is pretty terrible too...
In general, if you have rear drums, you need to swap to some properly sized rear disks, and then you will not have a rear wheel locking problem that can't be easily tuned with an adjustable prop valve
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
