69 charger door glass plastic guide were to get ?? #2571993
10/31/18 09:22 AM
10/31/18 09:22 AM
dracut mass usa
sparcy Offline OP
sparcy  Offline OP
dracut mass usa
The plastic strip that is fastened to the front of the door glass. What is that called? does anyone make it? and sell it? THANKS
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
Re: 69 charger door glass plastic guide were to get ?? [Re: sparcy] #2572030
10/31/18 11:26 AM
10/31/18 11:26 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
See this thread: Link
I just ordered mine from Tony's parts 2 weeks ago. Not cheap.....but original Mopar.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 69 charger door glass plastic guide were to get ?? [Re: sparcy] #2572031
10/31/18 11:27 AM
10/31/18 11:27 AM
Georgia
69bfan Offline
69bfan  Offline
Georgia
You would be looking for the mylar glass channel runs. Reproductions are available and generally retail in the $95 range. OEM pieces were discontinued early this past summer and now they are bringing $200 to $600 per pair.
If you should purchase the reproduction channel, reuse your original nylon "H-Pins" as the reproductions are a bit too thick. You can sand them down to make them work. You will have to cut both the reproductions and originals down to the proper length.
These pieces are very fragile so take extreme care as it does not take much to tear them. If your using reproduction side glass, we have found that it is typically a bit thicker and wavier than the original glass and will create issues as well with the reproduction glass channel runs.
www.restorationpartsandmaterials.com
Correct Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs.
www.dalescudashop.com
Correct style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
Re: 69 charger door glass plastic guide were to get ?? [Re: sparcy] #2572389
10/31/18 10:19 PM
10/31/18 10:19 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
I know a few are looking... but these would be a money maker if someone repoped them correctly...
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
