Re: 2019 Chevrolet Silverado’s Turbo Four Gets Disappointing MPG [Re: 360view] #2564469
10/15/18 04:41 PM
10/15/18 04:41 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Originally Posted By 360view
So, if a test Ram pickup truck were built with a
special non-turbocharged one cylinder engine with a 3.6L displacement,
1:1 bore/stroke,
four sparkplugs,
Three intake valves, 2 exhausts
direct fuel injection
variable timing,
vari-length intake runner,
single pipe stepped exhaust header,
and same emissions requirements,
would it get
better, same, or worse
highway MPG,
compared to a 3.6L Pentastar V6?
This taking the V12, V10, V8, V6, I4, B2 arguments to the extreme.
Would a single cylinder on the size order of a locomotive or ship engine,
loose less heat because of smaller internal surface area compared to volumetric displacement
and be more efficient?
Less. Larger cylinders are much less detonation resistant and that poses all sorts of problems to eeking out mpg, power and emissions needs.
Re: 2019 Chevrolet Silverado’s Turbo Four Gets Disappointing MPG [Re: Supercuda] #2564485
10/15/18 05:05 PM
10/15/18 05:05 PM
KY
benny70hemibird Offline
KY
LMAO
Re: 2019 Chevrolet Silverado’s Turbo Four Gets Disappointing MPG [Re: DaveRS23] #2564497
10/15/18 05:18 PM
10/15/18 05:18 PM
USA
3
360view Offline
360view  Offline
USA
Re: 2019 Chevrolet Silverado’s Turbo Four Gets Disappointing MPG [Re: DaytonaTurbo] #2564503
10/15/18 05:26 PM
10/15/18 05:26 PM
USA
3
360view Offline
360view  Offline
USA
Experiments have definitely shown that large diameter cylinders with one sparkplug detonate sooner than smaller diameter ones as BMEP is raised higher on the same Octane rating fuel.
That is why I tried to compensate somewhat with 4 sparkplugs and direct injection in the large single cylinder.
Re: 2019 Chevrolet Silverado’s Turbo Four Gets Disappointing MPG [Re: 360view] #2564508
10/15/18 05:45 PM
10/15/18 05:45 PM
O
oldjonny Offline
Don't argue with me.
oldjonny  Offline
O
Interesting analysis. When he 'gives it one year' that means that GM will be lucky, with rebates and incentives, to convince ANYONE to drive one. I will bet that they do a short term lease and offer an even better employee only deal to attempt to get some of these into the market. It will be the AsssTek of the Silverado lineup
Never, ever argue with an IDIOT. They will drag you to their level and then beat you with their years of experience
Re: 2019 Chevrolet Silverado’s Turbo Four Gets Disappointing MPG [Re: oldjonny] #2564580
10/15/18 08:48 PM
10/15/18 08:48 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Let's not forget there are plenty of stupid people who buy vehicles... runaway
JB Rhinehart, Realist
A-Body's RULE!
Re: 2019 Chevrolet Silverado’s Turbo Four Gets Disappointing MPG [Re: oldjonny] #2564735
10/16/18 08:36 AM
10/16/18 08:36 AM
Guitar Jones Offline
Originally Posted By oldjonny
Duh...its GM. They have already proven that they don't have to be smart enough to produce vehicles that make any sense or are reliable. They are still living on taxpayer money since the last bailout and are confident that when (not if) they fail, they will get another one. Does the ignition switch work?
laugh2 The hallmark (or is it haulmark) of GM engineering.
Hey, let's put a turbo 4 cylinder in a loaded full size pickup!
That's a really stupid idea, let's do it!
I never learned to count my blessings, I choose instead to live inside my disasters.
The Scamp is sold, now just two old trucks and one new one.
'74 W200 Crew Cab 360, NP435, D44, D60 and NP205 divorced transfer case. Magnum 5.2 MPI and NV4500 coming soon.
2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi!
Re: 2019 Chevrolet Silverado’s Turbo Four Gets Disappointing MPG [Re: DaveRS23] #2564834
10/16/18 02:21 PM
10/16/18 02:21 PM
up yours
Supercuda Offline
I want my mommy!!
Supercuda  Offline
I want my mommy!!
up yours
You can thank the 4 banger in a full sized pick up on the EPA's 50 mpg edicts. If GM had a choice you'd still be driving a square body with points.
Don't be the exception.
Re: 2019 Chevrolet Silverado’s Turbo Four Gets Disappointing MPG [Re: DaveRS23] #2564905
10/16/18 04:01 PM
10/16/18 04:01 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Trucks are heavy, even more so now and a 4 banger is just a bad idea.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Forum Statistics
Forums32
Topics193,575
Posts2,260,625
Members25,805
Most Online1,424
Jun 20th, 2018
7000 RPM Small block oiling mods.
by RUNCHARGER. 03/25/19 10:02 PM
99 ram p/u 2500 V10 2WD oil pan gasket replacement
by moparjo68. 03/25/19 09:27 PM
Valve Springs
by 71birdJ68. 03/25/19 08:38 PM
