Re: First time aluminum head build,anything special I need [Re: Brian_wo] #2568898
10/24/18 02:36 PM
10/24/18 02:36 PM
Maybe a Bowl Hog would be a better tool for removing those lips instead of doing it by by hand work scope
Re: First time aluminum head build,anything special I need [Re: Brian_wo] #2569043
10/24/18 07:08 PM
10/24/18 07:08 PM
Omaha Nebraska
Brian_wo Offline OP
Brian_wo  Offline OP
Omaha Nebraska
Don’t know what a bowl hog is but hand blending is working really well,aluminum is cutting like butter :-)
who is that guy?
Re: First time aluminum head build,anything special I need [Re: Brian_wo] #2569046
10/24/18 07:11 PM
10/24/18 07:11 PM
It is a tool designed to cut under the valve seats when you swap to bigger valves and valve seats up scope
I have learned the hard way on using carbide cutters on aluminum to be very careful with them up
Re: First time aluminum head build,anything special I need [Re: Brian_wo] #2569067
10/24/18 07:41 PM
10/24/18 07:41 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Be sure & round the edge on that short side that you cut straight
Re: First time aluminum head build,anything special I need [Re: CSK] #2569083
10/24/18 08:07 PM
10/24/18 08:07 PM
Omaha Nebraska
Brian_wo Offline OP
Brian_wo  Offline OP
Omaha Nebraska
It’s not as straight as it looks,also this picture was taken after a minute or two of grinding,I thought it really showed the lip.
I ordered more cutters(different shapes) and sanding rolls last night to pretty it all up.
I am a little nervous about cutting so close to the seats,hope that doesn’t bite me.
who is that guy?
