Torsion bars and sway bars #2560398
10/07/18 04:15 PM
10/07/18 04:15 PM
NC
70charger512 Offline OP
#1 Thread Starter
#1 Thread Starter
NC
So it looks like im going with a .96 torsion bar for my 1970 charger with a 440. Is there a certain proportion theres supposed to be between the torsion bar and sway bar? If not what would be a good size sway bar for daily driving? Thanks
Re: Torsion bars and sway bars [Re: 70charger512] #2560424
10/07/18 05:46 PM
10/07/18 05:46 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
1 1/8” to 1 1/4” front
Adjustable rear. If you choose to run one
Re: Torsion bars and sway bars [Re: 70charger512] #2561240
10/09/18 02:22 AM
10/09/18 02:22 AM
AndyF Offline
AndyF  Offline
You'll need a good shock with the big torsion bar and anti-sway bar. I recommend Koni shocks but there are some other choices that might work just as well.
Re: Torsion bars and sway bars [Re: AndyF] #2561295
10/09/18 09:19 AM
10/09/18 09:19 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Do you have a model Koni you look for? I have old Summit drag shocks on my 'Cuda and it's severely overdamped and the rear rides like a dump truck.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Torsion bars and sway bars [Re: GoodysGotaCuda] #2562204
10/10/18 11:38 PM
10/10/18 11:38 PM
dracut mass usa
sparcy Offline
sparcy  Offline
dracut mass usa
I have that exact set up in my 69 charger 96 T bar with a 1 1/8 Hotchkis sway bar. a 383 with Aluminium heads, intake and radiator. I have the edelbrok shocks I do not like the shocks. love the way car handles. my friend has the same set up with bilstein shocks I am going with them.
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
Re: Torsion bars and sway bars [Re: 70charger512] #2562392
10/11/18 12:38 PM
10/11/18 12:38 PM
AndyF Offline
AndyF  Offline
Bilstein shocks are good but they cost roughly the same as the Koni shocks and Koni's are adjustable.
Re: Torsion bars and sway bars [Re: 70charger512] #2571441
10/30/18 03:58 AM
10/30/18 03:58 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Why not Fox shocks? Get your spring rates, sprung and unsprung weights and have them valved to you needs. I am looking at 8-1100 per set of 4. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Torsion bars and sway bars [Re: astjp2] #2572292
10/31/18 06:07 PM
10/31/18 06:07 PM
So Cal
So Cal
Because It's seems he's just after mild improved street handling. Custom double adjustable are overkill and for his application probably not cost effective in terms of effect vs dollar spent.
If he was trying to control 1.20+" Torsion bars, going on 100+ mph track days, autocross events, lower profile wide grippy tires, and trying for max handling performance, etc, etc. then a custom double adjustable would make more sense.
Re: Torsion bars and sway bars [Re: 70charger512] #2572394
10/31/18 10:45 PM
10/31/18 10:45 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
iagree Well said.
The relationship is one debated in circle track. More important for this situation is the relationship of the front to rear roll rates.
If the rear becomes too stiff in relative to the front it will have more of a tendency to oversteer. Think fishtailing, especially on a wet downhill curve.
So if you are increasing the rear spring rates, or adding a rear sway bar, then a larger front sway bar, like 1.125" to 1.25" would be in order.
The stiffer the front sway bar, the less independent each wheel is. For street use, with typical all season radials, I wouldn't go too stiff. Try either stock factory or smallest aftermarket sway bar (which may be 1.125"), unless as mentioned above, you're adding a rear bar or stiffer leafs.
Removing wieght on either end of the car has similar effect to installing stiffer springs.
