The airraid hat is nice looking but I don’t think it’d fit. Those drop bases are smooth too but also go behind the carb too far.
This setup dropped right on and only needs a little hemmer and dolly work just behind it- there is only 1/16” now and I anticipate the motor will shake that much even with poly bushings. I’m going to try to neatly smash 3/16” or 1/4” clearance behind it. It looks like the hood will clear fine & if not the 4” tubes can get added to and routed with common turbo intake stuff. Or even a ram air or cold air setup later if I get bored of bodywork.
