Re: Caravan cruise control issue ....
[Re: therocks]
#2564049
10/14/18 08:46 PM
10/14/18 08:46 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Ron. Doc dosent probally want to spend $$$ on diag.Most peopledont.They will spend a bundle guessing etc but when it comes to paying say 100 bucks for diag no way.Saw it all the time at work.Rocky Believe me living on disability I completely understand. To bad he don't have a friend working at a dealer who could check it for him as a favor. I did that a lot for my buddies but I was a shop foreman and had a key to our shop and could stay as late as I liked. Ron
[Re: dOc !]
#2564690
10/16/18 01:05 AM
10/16/18 01:05 AM
Posts: 12,591 Great Neck,LI,new york
hemi-itis
I would not do a hard reset 'till after reading the currant codes with a scanner.As Ron and Joe said,hook to a good scanner!!!
[Re: dOc !]
#2564725
10/16/18 04:44 AM
10/16/18 04:44 AM
Posts: 20,655 in a cattle trailer down by th...
Guitar Jones
I hear you itis .. Define a good scanner ? None of the aftermarket scanners can hold a candle to the factory piece.
[Re: dOc !]
#2564852
10/16/18 02:49 PM
10/16/18 02:49 PM
383man
Balt. Md
Yea the factory scanner I used on yours would be the DRBIII as it could do so much when diagnosing Mopars it was great. I don't know if any other scanners will do as much because I always used the Mopar scanners. But you should at least be able to see it any codes are set with any scanner. Since the PCM works your cruise it can set codes for most everything on the cruise circuit other then a vacuum problem to the servo which that don't sound like your problem. Ron
