89 LA roller block question #2560575
10/07/18 11:14 PM
10/07/18 11:14 PM
Willow Spring
dagohman Offline OP
dagohman  Offline OP
Willow Spring
How much camshaft can the factory hyd roller lifters and spider support? The engine in question will be a mild build shooting for around .560 lift.
Re: 89 LA roller block question [Re: dagohman] #2560760
10/08/18 10:59 AM
10/08/18 10:59 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Mine has .550 lift with stock lifters...just gotta make sure you set up the springs correctly on the head side.
Re: 89 LA roller block question [Re: dagohman] #2560804
10/08/18 12:15 PM
10/08/18 12:15 PM
Willow Spring
dagohman Offline OP
dagohman  Offline OP
Willow Spring
Thanks!
Re: 89 LA roller block question [Re: dagohman] #2561386
10/09/18 01:21 PM
10/09/18 01:21 PM
CA
W
wyrmrider Offline
wyrmrider  Offline
W
CA
550
is this a magnum or LA HR build?
on an LA I recommend Iron rockers but have run stock
I recommend oil through the pushrods to oil the stock rocker cups and pushrod ends to hold off pushing the pushrod through the rocker
