Re: My Daughter's 69 Charger R/T
[Re: 70runner]
#2560457
10/07/18 07:07 PM
10/07/18 07:07 PM
Posts: 1,177 People's Republic of Kali
70runner
For the exhaust manifolds I used a product called Slip Plate - Graphite Lubricant. Came highly recommended from a pro mopar restorer. Just clean, wirebrush the manifolds, then spray this stuff on. It still looks perfect like the day it was applied. Much better than the Eastwood stuff I used on the RR.
[Re: 70runner]
#2560487
10/07/18 07:55 PM
10/07/18 07:55 PM
70runner
A before/after...
Note the aftermarket Edelbrock 1813 AVS carb, an 800cfm rig. This was recommended by the engine builder instead of restoring the original AVS. Although physically very similar to the orig AVS, the Edelbrock required some electrical adaptation as the Edelbrock choke is electrically controlled while the orig AVS is heat controlled. We kept the orig AVS and may, in the future, bring it back to life to restore originality.
[Re: 70runner]
#2560491
10/07/18 08:20 PM
10/07/18 08:20 PM
70runner
So daughter is enjoying her ride...until a fateful day in Apr18 when the engine decides to take a siesta while traveling down a local freeway. So dad dusts off the (nice to have it when you need it) car hauler and arrives to meet with a frustrated daughter on the roadside. We haul it to dad's place and discover a fuel supply issue.
The output side of the relatively new mechanical fuel pump was marginal, so we track down a new fuel pump and, walla, same problem. This time dad inspects the fuel pump pushrod, which has lost about 1/4" of it's length in a couple months (shown below compared with a new one). So those pushrod shavings are now in the oil pan, hopefully captured by the oil filter.
A little research discovers that some brands of pushrods are infamous for wearing out prematurely and, further, that the best option is to locate some NOS versions...which I did thx to a fellow moparts member.
So we do two oil and oil filter changes in close proximity to hopefully remove the shavings. And daughter resumes her Charger activities, until...
[Re: 70runner]
#2560513
10/07/18 09:00 PM
10/07/18 09:00 PM
70runner
...a few weeks later (early May) when the Charger decided to take another siesta while briskly moving with freeway traffic. This time she had it towed by her insurance.
Checks revealed good fuel pump pressure and flow, but no spark. Commenced troubleshooting the ignition system now built around a Firecore Ready to Run (RTR) distributor and special coil, shorted (no) ballast, Firecore spark plug wires, and electronic voltage regulator. All evidence pointed to distributor, so contacted Firecore. Went through their troubleshooting process, and everything seemed to check out. But Charger would not start, still no spark.
In consult with the owner, I decided to reinstall the original points distributor, stock coil and ballast resistor. Engine started right up and ran perfectly.
I again contacted Rick at Firecore. He asked me to ship the RTR to him with the coil for a "factory check", which I did. Heard nothing for a month, so called him. He said the RTR would have to be returned to the purchaser (engine shop) so they could initiate a refund with the seller (Summit Racing).
I asked him to ship it directly to the engine shop. About 2 weeks later received a box with the RTR. I guess Rick was confused. So I send it to the engine shop. Long story short I finally got the refund about 3 months after initially contacting Firecore. Apparently they were in the middle of shedding their sales/support operation to major retailers like Summit. Even so, I am quite unimpressed with their product and service.
[Re: 70runner]
#2560871
10/08/18 01:43 PM
10/08/18 01:43 PM
Superfreak
Superfreak
Your daughter is lucky to have a great dad. Car looks awesome!
[Re: 70runner]
#2561279
10/09/18 05:03 AM
10/09/18 05:03 AM
70runner
I forgot to add one of the other little projects. The original owner had added a radiator overflow container because the radiator would vomit a bit when hot. The overflow container was kind of an eyesore, but the current owner wanted something similar to avoid coolant spills. Another bit of research turned up an option to use an overflow bottle from a 97-02 Mitsubishi Mirage (pic1). This design fits nicely into the cavity between the radiator and battery tray. Just needed to fab a bracket (pic2) that would secure it in place.
[Re: 70runner]
#2567590
10/22/18 12:28 AM
10/22/18 12:28 AM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
Cool car and cool story! Nice work.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: 70runner]
#2574682
11/06/18 01:23 AM
11/06/18 01:23 AM
Posts: 16,469 On the run…
BloFish
On the run…
Enjoyed every bit of the story, congrats!
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: 70runner]
#2575750
11/08/18 09:40 AM
11/08/18 09:40 AM
Posts: 8,128 New Mexico
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
For the exhaust manifolds I used a product called Slip Plate - Graphite Lubricant. Came highly recommended from a pro mopar restorer. Just clean, wirebrush the manifolds, then spray this stuff on. It still looks perfect like the day it was applied. Much better than the Eastwood stuff I used on the RR. Do you mean Eastwood's Exo Armor? It say's it's "Tested to 2000F degree for temperature resistance" It can leave a shinier appearance when laid on heavy. I'm curious how it holds up on exhaust manifolds
