T56 Magnum / TKO 600 / 18 spline A833 Passon OD 4 speed
#2558024
10/02/18 11:35 PM
10/02/18 11:35 PM
Posts: 1,004 Central US
grancuda
Central US
Finally decided to put a stick shift OD in my ‘67 Barracuda that’s a 383/727/4.11/3000# car that I use primary as a daily driver. Been kicking it around for a while & the cost just makes it un-appealing but I just went ahead & sold my ‘72 SWB to fund the swap.
Back around ‘01 I swapped a 833 for a Keisler TKO 500 5 speed in my ‘70 Barracuda & it worked out great but there are lots more choices these days & it was a stock 360. I really am shooting for a set-up to handle the drag strip & shooting for low 12’s/high 11’s.
I’m really wanting to run a mechanical clutch instead of hyd. for simplicity but the T56 Magnum is only available with the hyd. set-up.
What’s the experience you guys have had with banging gears in the newer transmissions vs the rebuilt A833.
Any advice/tips/stuff to watch out for?
1967 Barracuda Formula S 383 1967 Chevy C10 Short Stepper 1980 Macho Power Wagon LWB 318 2021 Toyota Supra
Re: T56 Magnum / TKO 600 / 18 spline A833 Passon OD 4 speed
[Re: grancuda]
#2558073
10/03/18 01:59 AM
10/03/18 01:59 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
My only experience with any of the newer overdrives has been with the tko600. I say that if you are going to put slicks or even drag radials on at the track, stay away from the tko. I know there have been many others who have been/are successfully racing them in their cars, but i broke 3rd gear 3 times. 1st timw with drag radials. 2nd and 3rd times with slicks. And the 3rd time was after having Liberty faceplate the gears. Broke on the first run after that. However, i am much heavier at 3,900 lbs.
I do use the tranny for street/hwy driving and absolutely love it. It is perfect for that. If you absolutely have to run that, i would think about getting an adjustable slipper clutch that you can dial in some slip to lessen the shock load on the tranny. These clutches are not really optimal for a true street car that gets driven heavily. This is just my experience for what it’s worth and in no way am i bashing the tko. I do believe it is a stout tranny and has its place. Just not on the track in my car anymore.
By the way, the breakage was done with my old motor that ran 11:40s. Not my current motor
[Re: grancuda]
#2558228
10/03/18 01:34 PM
10/03/18 01:34 PM
Posts: 7,477 Minnesota
Hemi_Joel
Minnesota
I just finished drag week with a T56 Magnum behind a 392 Hemi in my 31 Plymouth Coupe. This is my first experience with the T56 Magnum. I was holding off on reporting my opinion because I have not as of yet thoroughly evaluated it. But since the topic came up I will let you know my findings so far. With the clutch out idling in neutral and the car stopped, the transmission makes a lot of noise. The noise doesn't bother me, but it makes me wonder if something is wrong. I've heard from others on the web that they are known for being noisy under these circumstances. On the street the transmission is awesome! It shifts nice. The gear spreads are great. But if you're going to use 6th gear, you better have deep gears or a Torquey engine! I have 4.57 gears in the rear end, 30 inch tires, and at 70 miles per hour in 6th Gear the engine is turning 2200 RPM. This engine has a huge cam, and barely runs at 2000 RPM, so I never used 6th unless I was going 75 mph+. I also had trouble trying to power shift at 7000, it would hang up. If I lifted off the gas, it shifted reliably, and reasonably quick. But this could be clutch related. My soft lock clutch has an iron disc, which is heavier than an organic or Kevlar disc. Plus counter weight on the levers which can hinder high RPM release. So before I can really make a call on the power shift ability, I need to work on the clutch more. I hope this info helps.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: grancuda]
#2558421
10/03/18 05:04 PM
10/03/18 05:04 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Based on the 3 options, no doubt I'd go t56. It is the most work also though as mentioned, takes some cutting. I wouldn't mind having one of Passons 5 speeds for my belvedere, but I lack the patience to wait for one.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: JAMESDART]
#2558462
10/03/18 05:43 PM
10/03/18 05:43 PM
Posts: 22,695 Bitopia
jcc
Bitopia
I'm waiting on the buzz from the field on the GForce remade 3650 5 speed, and with its size, and $4650? down stroke.
Last issue of Hot Rod had the write up.
[Re: grancuda]
#2559856
10/06/18 01:09 PM
10/06/18 01:09 PM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
I did a 394Ci G3 Hemi for a guy who has a Gforce 3650 trans in a 98 Dakota, he's hurt the 9 inch rear twice but the Gforce3650 is going strong. truck has run as fast as 10.10 @ Island and Maple grove went 9.90a truck weighs in @ 3700 race weight. the 3650 can take some punishment with the GForce set up also Pro-Force out of Lawrenceville Ga builds a respectable 3650 trans.
that being said, I think the T-56 /6060 is you best bet.
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: Hemi_Joel]
#2560023
10/06/18 07:14 PM
10/06/18 07:14 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I just finished drag week with a T56 Magnum behind a 392 Hemi in my 31 Plymouth Coupe. This is my first experience with the T56 Magnum. I was holding off on reporting my opinion because I have not as of yet thoroughly evaluated it. But since the topic came up I will let you know my findings so far. With the clutch out idling in neutral and the car stopped, the transmission makes a lot of noise. The noise doesn't bother me, but it makes me wonder if something is wrong. I've heard from others on the web that they are known for being noisy under these circumstances. On the street the transmission is awesome! It shifts nice. The gear spreads are great. But if you're going to use 6th gear, you better have deep gears or a Torquey engine! I have 4.57 gears in the rear end, 30 inch tires, and at 70 miles per hour in 6th Gear the engine is turning 2200 RPM. This engine has a huge cam, and barely runs at 2000 RPM, so I never used 6th unless I was going 75 mph+. I also had trouble trying to power shift at 7000, it would hang up. If I lifted off the gas, it shifted reliably, and reasonably quick. But this could be clutch related. My soft lock clutch has an iron disc, which is heavier than an organic or Kevlar disc. Plus counter weight on the levers which can hinder high RPM release. So before I can really make a call on the power shift ability, I need to work on the clutch more. I hope this info helps. For what it's worth, I have no noticeable noise at idle, but I do get a decent rattle under heavy load, which is amplified by the long pistol grip handle. I've done plenty of 6000rpm no-lift-shifts [ECU cuts spark/fuel] with no issues. 6th gear use depends on the gear set, I have the close ratio T56 with the 0.63 6th [not the 0.50] and 6th is very functional for me.
[Re: Silver70]
#2560073
10/06/18 08:51 PM
10/06/18 08:51 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
Based on the 3 options, no doubt I'd go t56. It is the most work also though as mentioned, takes some cutting. I wouldn't mind having one of Passons 5 speeds for my belvedere, but I lack the patience to wait for one. There's a thread with lots of pics on FABO by a guy who just did it. "Some cutting" is an understatement It came out great in the end, but he also included a price list. Cost about $6000 AND he did a huge amount of surgery. Meanwhile, although it may take a long time to get one, the Passon A855 is $5500 and bolts right in
[Re: ric3xrt]
#2560103
10/06/18 09:51 PM
10/06/18 09:51 PM
Posts: 10,551 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have a Richmond 5-speed I built for racing and I currently run an 833 street HEMI 4-speed for just street driving. I have built a few overdrive 18 spline boxes with Jamie Passon's overdrive gear sets and they turned out good. I think you are smart to want mechanical or external clutch operation. I would HATE to have a hydraulic release bearing fail because you need to disassemble everything to replace it. I have been inside a few Viper T56 transmissions they seem plenty strong enough but they are not known for their power shifting. I like the Richmond for the 3.27 low gear and 1-1 final drive that way you can run a 3.23 gear in the diff for good road manners at 70 MPH. Just make sure you spend some time with your fabrication the first time and make sure your driveline angles are correct. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: DrCharles]
#2560113
10/06/18 10:15 PM
10/06/18 10:15 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Based on the 3 options, no doubt I'd go t56. It is the most work also though as mentioned, takes some cutting. I wouldn't mind having one of Passons 5 speeds for my belvedere, but I lack the patience to wait for one. There's a thread with lots of pics on FABO by a guy who just did it. "Some cutting" is an understatement It came out great in the end, but he also included a price list. Cost about $6000 AND he did a huge amount of surgery. Meanwhile, although it may take a long time to get one, the Passon A855 is $5500 and bolts right in Meanwhile I built my car in the amount of time some people have been on the waiting list for a Passion, and I can guarantee service parts will be around, if I ever need them.
[Re: DrCharles]
#2560128
10/06/18 10:40 PM
10/06/18 10:40 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Meanwhile I'll built my car Were you trying to say you DID build your car, or will have built it... actually I don't care. I'll be driving mine with the A833 anyway ...did.
[Re: DrCharles]
#2560143
10/06/18 10:53 PM
10/06/18 10:53 PM
Silver70
Rust Belt, SW PA
Based on the 3 options, no doubt I'd go t56. It is the most work also though as mentioned, takes some cutting. I wouldn't mind having one of Passons 5 speeds for my belvedere, but I lack the patience to wait for one. There's a thread with lots of pics on FABO by a guy who just did it. "Some cutting" is an understatement It came out great in the end, but he also included a price list. Cost about $6000 AND he did a huge amount of surgery. Meanwhile, although it may take a long time to get one, the Passon A855 is $5500 and bolts right in I never said it takes a little cutting I already have all the parts to do the same swap into my cuda and I'm no where near 6k, maybe half that. I went with a low mileage viper t56, new quicktime bell, mcleod twin disc, billet flywheel, etc... not junk parts. My belvedere was a 4 door converted to a 2 door, last thing that would bother me is cutting out the tunnel. I'm not waiting 5 years for a transmission.... that whole thing is a mess on those 5 speeds. If you could pick up the phone, order one and have it in a week, that would change everything, but 5500 is far more than I get put a t56 in a car for.
