Electrical Problem 1971 Duster #2557835
10/02/18 06:25 PM
10/02/18 06:25 PM
Eastern,NC
68GTS383 Offline OP
68GTS383  Offline OP
Eastern,NC
My Duster will not start. It will turn over but not fire.
If I pull the coil wire off and turn the engine over it will arc when the key is turned on then no arc while the engine is turning. When the key is turned off it will arc. What causes this? It has the 2 wire distributer Thanks!
Re: Electrical Problem 1971 Duster [Re: 68GTS383] #2557848
10/02/18 06:46 PM
10/02/18 06:46 PM
Check the ballast resistor connections for 12 volts with a volt ohm meter on the coil side of the resistor with the key in the start position now scope
Another issue can be caused by bad grounds on the electronic ignition box also scope
Re: Electrical Problem 1971 Duster [Re: 68GTS383] #2557920
10/02/18 08:27 PM
10/02/18 08:27 PM
CA
crackedback Offline
crackedback  Offline
CA
Buklkhead is another spot where the wires have a bad connection.
Check the brown and blue wires for power in start and run.
Re: Electrical Problem 1971 Duster [Re: 68GTS383] #2557985
10/02/18 10:25 PM
10/02/18 10:25 PM
Andrewh Offline
Andrewh  Offline
if you put the key to on and then jump the starter relay, see if it runs.
if it runs, then either the ignition switch, bulkhead connector or the connector at the bottom of the column(assuming column switch ignition)
could be bad and not letting power go in the start position.
the balast resistor is bypassed during start.
Re: Electrical Problem 1971 Duster [Re: 68GTS383] #2558037
10/02/18 11:50 PM
10/02/18 11:50 PM
Hold the coil wire (dist end) 1/4 from ground. key on. seperate the dist pickup zigzag 2 wire connector & drag the male tip of the body half of the connector across the intake to make/break ground & see if the coil wire sparks. Pull the yellow wire off of the "ign" terminal on the starter relay & have someone hold the ign key to "start" & redrag the connector & see if the coil wire sparks. check the reluctor gap in the dist (.008" with a brass feeler gauge) but "very close" is good enough for now. is this a 5 pin ECU/4 terminal "dual" ballast system or a 4 pin ECU/2 terminal "single" ECU system? Can you ohm your ballast for continuity?
